How do you apply wax/sealant?
  • How do you apply wax/sealant?
    I have a PC 7424 and use it for applying cleaners and polishes. I have used it to apply wax as well, but not sure there is any benefit compared to hand applying. I actually prefer hand application of wax as it seems to be faster and is easier to get into tight areas.
    Re: How do you apply wax/sealant?
    I myself would opt for applying by hand as well. I think it gives you a more feel for what you are doing but...if you don't have the time then go for a power option.
    2011 Mitsubishi Lancer GTS, Octane Blue
      I also use a machine to apply wax/sealants. reason is its faster and I can apply a thinner even layer. I know by hand I will use more product and lay it down thicker and I am more likely to miss spots.
      Really tight areas go over by hand like around wing mirrors
        I often go around the tight areas by hand first, then use the PC to apply the wax to the rest of the car. Like already mentioned it helps give a thinner more even coating.
        Don
        12/27/2015
        "Darth Camaro"
        2013 Camaro ... triple black
        323 hp V6, 6 speed manual
          I think the machine gets you thinner coats. But do what you enjoy, no harm in that.
          I really like removing by machine though.
            I prefer to use a PC in applying my LSPs but it never gets done all the time. When I feel lazy setting up the PC and the proper backing plate then I just apply the LSP by hand.
