glimour foam gun.. what soap for most suds?
  • Murr1525
    replied
    Re: glimour foam gun.. what soap for most suds?
    Well, you can play around a bit, but you could say:
    - Use the 12oz per gallon setting. 12:128 = 1:10.6
    - Using the quart size bottle, mix one oz soap in 32 oz of water. 1:32
    - Final ratio: 1:340ish..
    So could try that, or a hair less soap, or the next lowest setting on the gun... whatever you like.
  • Ced
    replied
    Originally posted by Andrew Wilson View Post
    Hyperwash foams really well.
    Being that Hyperwash has such a high dilution ratio (400:1), how would we dilute it to be used with the foam gun? Meguiar's other soaps specify 1oz to every gallon.
    The lowest setting on the foam gun is 1oz to every gallon of water and the highest setting is 12oz to every gallon of water.
  • bghere
    replied
    Originally posted by dedonderosa View Post
    looking to know what kind of soap you guys are using for your glimour foam gun. i tried using meg deep crystal car wash and was very unhappy with the results, barely any suds at all. looking for a car soap that is gonna make a ton of suds with good cleaning agents and for good lubrication. let me know what you guys are using thanks.s
    two words
    Meg's Hyperwash
  • Tuck91
    replied
    I never use the recommended ratio, I probably use more than I should be but its no big deal.
  • wifpd4
    replied
    Originally posted by Hellspawn View Post
    Get it too strong and it will strip wax?
    It's my thinking, while the chemicals in an automotive soap may not, in recommended dilution rates, remove wax. Above those recommendations and or combined with the mere mechanical action of washing the car, you may lose wax.
    I would think Meguiar's recommendations are based on the best case scenarios for the broadest range of situations. A nearly impossible task given all the possible variables that come into play, but they do a great job!!
  • Murr1525
    replied
    I would venture a guess the ratio on the gun may not be exact either, so I go on the safe side.
    I guess i figure I would use 4-5 ounces of soap for one wash in a bucket, so if i use 4-5 ounces of soap with the gun, no big deal even if more than needed. And at least I can save the water in the gun, not like just throwing out a bucket.
  • wifpd4
    replied
    Murr, I agree that it is a delicate balance. Too little soap and you lose the lubrication and cleaning ability. Too much soap and it maybe difficult to rinse off with diminishing returns and wasting money.
  • Marc Hufnagel
    replied
    Yeah, I'd consider an extra ounce or so added in. Dont really want to be under the ratio, I dont think.
  • Murr1525
    replied
  • wifpd4
    replied
    What ratio are you all using? I was trying 2oz of wash to 30oz of water. Tried GC and NXT.
    bar pushed all the way to the left.
    This combination, 2oz+30oz and 1:10, equals about 1:160, which is very close to the recommendation on the label of Super Soap of 1:128.
  • Marc Hufnagel
    replied
    At what ratio on the gun?
  • nothelle
    replied
    Saw my friend put shampoo plus (gotta be at least 1.5oz to 2oz) per quart botle, leaves a good foam but disappear quite fast.... I got better foam and durability from other brand soap.
  • Murr1525
    replied
  • Marc Hufnagel
    replied
  • Andrew Wilson
    replied
