Exterior Trim Coating
Re: Exterior Trim Coating
Bad news: it was discontinued
Good news: it's coming back as Vinyl & Plastic CoatingMichael Stoops
I've used the Vinyl & Plastic Coating before its just not nearly good as the trim coating. if the Vinyl & Plastic Coating was in a "spray can" type will be good but its a spray bottle type.
whats the reason meguiar's discontinued the trim coating?
Originally posted by Racingfan View PostI've used the Vinyl & Plastic Coating before its just not nearly good as the trim coating. if the Vinyl & Plastic Coating was in a "spray can" type will be good but its a spray bottle type.
No threat to the clear coat - the product actually wipes off of paint quite easily if you get some overspray on it.Michael Stoops
Originally posted by Michael Stoops View PostWe think you've misunderstood something here - the Vinyl & Plastic Coating is a new name and it's not quite out yet so you couldn't have used it in the past. It's also not a trigger spray product, it's an aerosol can just like the old Accent Coating or Exterior Trim Coating that this thread is referencing. If you liked either of those two you're going to like this one just as much.
Originally posted by Michael Stoops View PostWe think you've misunderstood something here - the Vinyl & Plastic Coating is a new name and it's not quite out yet so you couldn't have used it in the past. It's also not a trigger spray product, it's an aerosol can just like the old Accent Coating or Exterior Trim Coating that this thread is referencing. If you liked either of those two you're going to like this one just as much.2016 Focus ST
