Re: how important is polish for hydration?
I would think that the micro fissures being filled in with oil would have a protective effect- I'm thinking along the lines of water not being able to enter the micro fissures to further corrode the paint and cause them to get larger. I hope someone from meguiars chimes in on this. For what I've been using Meguiars polishes on all my families cars since 1996 and for ever day drivers it has always made the paint look like brand new forever. One of my cars now is a 12 year old every day driver and the paint still has a like new luster from years of meguiars polishes
Originally posted by TOGWT View Post
This is one of the reasons foe using the wipe-down process
- Wash
- Clay
- Clean/Correct
- Polish
- Synthetic Wax
- Synthetic Wax
Trying to catch the drift here, but the implication is polish on a modern clear coat provides no useful function to hydrate and may actually interfere with the bonding of synthetic wax.
Just to chime in....
Products like M05, M07, M45, M81, etc will have greater impact on older single stage paints where the oils in these products can nourish the paint.
However, on modern clear coats, the products oils do not enter the pores, but instead fill in the micro-fissures on the surface of the paint, thereby creating a smoother and *perhaps* a more reflective finish. I say perhaps as with proper compounding, polishing and finishing steps, it is unlikely you would see that dramatic of a difference on most clear coats.
Originally posted by TOGWT View PostMost modern automotive paints are water-based and the resin binder system no longer requires oils to help the paints elasticity the way they were with Nitrocellulose Lacquer.
The oils used in polishes and compounds are used to provide surface lubrication
The oils used in Carnauba waxes will provide jetting (the so-called wet look), oils on a paint surface will negatively affect the bonding and therefore the durability of a polymer sealant. This is one of the reasons foe using the wipe-down process
However I think there are a few instances where the paint is somewhat confusing. For instance generally german paint is very hard and will absorb nothing and looks good for years after it's been fully corrected. On the flip side Honda or generally japanese paint is very soft. I've seen the paint on these cars looking disgusting after (for instance) 6 months on from a full correction.
When going over with a swirl spotter there are no real swirls or defects to write home about, but the paint has gone from white to a milky off white. When examined further the paint appears to have absorbed grime over those months despite being waxed or sealed using good quality products.
The only way I've seen to correct this is to hit it with a deep cleanser/finishing polish.
Originally posted by therdrman View Postpolish brings out the paints beauty. it will defenitly help your paint
Using a polish by hand will correct very little, mostly just cleansing the surface.
Hitting the paint with a rotary and the correct or even numerous grades of polish will bring out the paints beauty. Depending on how bad the paint is you may have to wet sand the paint and then use a number of grades of polish, reducing in aggressiveness to fully bring out the paints beauty.
But not true for Meguiars polymer sealants. M07 and NXT 2.0 or even Ultimate Wax are compatible.
I have not used the wolfgang yet but the reviews seem to be very good.
How good is this wolfgang deep gloss?
Found the website but I never heard of it.
It has to do with the pores of the paint. As paint ages, its pores grow larger and larger allowing more oils to be absorbed into the paint.
Older clears will benefit from a pure polish but as Murr said, not as much as older single stage paints.
My truck is a 99 with CC.....I definitely see an improvement when I use #7.
I haven't done the wolfgang yet. I was at least going to clay first, maybe M07 also. I usually use a combination of 7,20, 21, and 26 (not all at once).
So sure, a little polishing oil could be good, it is clear coat, but 14 yrs old.
Did you use a paint cleaner, cleaner/polish ,etc first?
Its a 97, clear coat paint. I'm doing some scary that I have not done in years which is use a non-megs sealant (wolfgang deep gloss)
