How to use PlastX??
  • How to use PlastX??
    hi guyz..I hav 2 question..
    1. i've just used PlastX on my yellowed headlight..why it didn't work..i was wondering if i do it wrong..can u guyz tell me the correct method??
    2. bout the masking tape..is it okay with ANY masking tape or i should use a specific brand??coz when i use the masking tape i pick from the supermarket near my home, when i remove it from my car, it leaves sticky residue and it can't get off when i rub it with water and towel..what shud i do??
    thx..
    Re: How to use PlastX??
    Masking tape that is labeled for delicate surfaces.
    If the lights have oxidation build up, you're going to need wet sand them down (progressively getting to finer and finer sand paper)
    Once you see the oxidation is gone (sort of like spider webs, or crows feet..usually yellowish) and you've got an even surface. Then go with the swirlx.
    It can be a little more work sometimes than it seems, it all depends on the condition of the lights to begin with.
    This is my technique, and it works well for me. I wont say everyone does it this way.
      well..i don't know how to use sand paper..
      do i need to let plastx haze first or i should just wipe them off after i spread them??
      do i need to put pressure when applying it??
      thx..
        thx..
        Are you just using the PlastX by hand or do you have the Headlight Restoration Kit with the drill attachment?
        By hand, spread some PlastX out on the headlight, and work it in for about a minute or so with some moderate pressure, and remove. In a sense you would use this like a paint cleaner, it is not a spread, haze, and wipe off application, it is working with you as you work the product in to remove the defects.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          i work with hand..
          thx nic...i'll try it tomorrow....if the yellow headlight can't be use with plastx, can i use UC or it would be just the same??
          thx..
            If after a few applications with PlastX by hand do not acheive results, you would most likely want to use one of Meguiar's Headlight Restoration Kits, which come with a wool pad attachment for a drill.
            Nick Winn
            Irvine, CA
            nawinn@meguiars.com
              yeah..i want to buy it too..but it's so damn expensive here in indonesia..it's like 56 us dollar..hahhaa...
              can i use UC on it??
                Yes, you can try UC, but you may need the power of the drill attachment & PlastX. There is only so much you can achieve by hand.
                Nick Winn
                Irvine, CA
                nawinn@meguiars.com
                  just be careful. take a microfiber fold it so it is comfortable in your hand. add some plastX then rub it in until it is gone. go for a 2nd application if needed. then wipe off with a microfiber then your done
                  Click For My Main Youtube Channel
                  Click For My Meguiars Review Channel
                  ^^Meguiar's Review Specialist^^
