NXT Tech Wax Over Cleaner Wax?
  • NXT Tech Wax Over Cleaner Wax?
    Just got the Meguiar's clay kit (which comes with a little bottle of cleaner wax and a towel..cool stuffs ) and also purchase a bottle of the NXT Tech liquid wax.
    Now my question is, can I use the NXT Tech Wax as my last coat after I done with my clay and cleaner wax? Will it actually defeat the purpose of using the cleaner wax?
    My steps will be as follows;
    1) Clay
    2) Sratch X
    3) Cleaner Wax
    4) NXT Tech Wax (or should I give this a miss?)
    Hope to get some feedback and advices!
    Thank you!
    Re: NXT Tech Wax Over Cleaner Wax?
    1) Clay
    2) Sratch X
    3) Cleaner Wax
    Yes, absolutely, you may top Cleaner Wax with NXT. This is a popular combination. See this article: Your Daily Driver: A Simple Wash & Wax Regimen.
    --Al Kimel
      Thanks mate!
        yup definitely able to use both together.
          Not a problem
          2011 Jet Black 328i Touring
          2007 Jet Black 335i Sedan
            1) Clay
            2) Sratch X
            3) Cleaner Wax
            Thank you!
            you may also want to apply a pure polish after the cleaner wax, I used DCStep2. Pick up a bottle of Meg. Gold Class Wax and apply that as your final layer. Your steps will be:
            Wash and dry
            Clay
            Scratch X
            Cleaner Wax
            *OPTIONAL Dilute a 50/50 solution of Isopropanol alcohol and water into a spray bottle, mist and wipe your vehicle dry, this will remove any wax you might have missed.
            Polish
            NXT (2 coats)
            Gold Class (2 coats) this will add a more glossy look to your car especially if its dark in color.
              Wash and dry
              Clay
              Scratch X
              Cleaner Wax
              Polish
              NXT (2 coats)
                I think it is a great combo. Go ahead.
                  Wash and dry
                  Clay
                  Scratch X
                  Cleaner Wax
                  Polish
                  NXT (2 coats)
                  Imo polish is bit of waste, maybe some #21 instead?!?
                    if he uses #21 then he wouldn't have to use NXT, those 2 products are the same.
                    When I said polish I meant a pure polish http://www.meguiarsdirect.com/detail/MEG+A2116.
                      Sorry, but I am a noob here, where can I actually find all the list of the part numbers here in the forum? eg, #21 = ????
                        #21 = Synthetic Sealant
                        On the main page on the right side, there is a link called The Numbers.
                          Thanks mate!
