Streaking - Why?!?
  • HealthyCivic
    replied
    Re: Streaking - Why?!?
    Thanks Mike, I'll give that a shot. I already have UQW so it shouldn't be too hard. I think those smaller things are the key for me right now. I'm still adjusting to my current school schedule...
    Now On the up-side, I dug up the time to have a co-worker over and clay and UC his ENTIRE car last night, teaching him about Meguiar's products and how to properly use the DA. He was SOOOO HAPPY afterwards. He had a black 4 year old Ford Focus with a ton of swirls and abuse. A lot of his scratches were tiny scratches that were through the paint on the hood, but even then, UC cleared his paint up like a dream and it looks brand new. He said the word "legit" like 500 times last night and he's super excited. In addition, all the neighbors started watching and learning a bit too, haha. It's times like these when I can showcase Meguiar's products and make someone happy that I wish you guys were a little bit closer to my house so I could apply. I love teaching this stuff and I've learned a lot of great things from you, this forum, and Mike Phillips.
  • Michael Stoops
    replied
    Originally posted by HealthyCivic View Post
    About 5 months ago. I just waxed it since I wrote this thread. Hopefully that'll solve it.
    Yep, that's really stretching it for any wax or sealant. We're willing to bet you see an immediate improve with the fresh coat of wax.
    I'm also going to try UW&W.. I'm hearing that it makes drying easier. Usually, for me, I just wanted mainly lubricity and conditioners... However, my needs have changed. I'm much busier now so I don't have as much time to work on the car, and I think that if UW&W makes drying easier, it will reduce water spots. And reducing water spots will ultimately help my finish.
    It can make drying faster and easier, but that alone won't decrease the incidence of waters spotting - you still need to get the water off the car.
    You might want to give this a try, especially since things have changed for you and the time you can give to your car is being reduced: when drying, do the final rinse with the nozzle off the hose, letting the water just gently flow over the paint. This will sheet off the majority of the water beads (the fresher the wax coating, the better this works) and then use some Ultimate Quik Wax in your drying process. Spray a panel with just two or three trigger pulls of UQW, then dry the panel as you normally would. Continue this around the vehicle and you'll be boosting your shine and protection as you go.
  • HealthyCivic
    replied
    When is the last time you just plain old waxed the car? When QD sprays become difficult to wipe off that is often a sign that your wax protection has faded and a fresh coat is due.
  • fullbirdmusic
    replied
    That would be my guess. Along with a quick claying beforehand.
  • J. A. Michaels
    replied
    It may also be time to rejuvenate your towels. Next time you wash them, add a 1/4 cup of vinegar, do a extra rinse cycle or two. This helps them become more absorbent again.
  • Michael Stoops
    replied
  • akimel
    replied
    Laundry-wise, I just throw them in the washer in their own batch with All and on warm water. I then tumble-dry on medium heat with no fabric softener.
    Do you have the sense that the towels are not absorbing water as well as they should? If so, you might try washing them hot water rather than warm water. Also try adding a some distilled vinegar to the first rinse cycle and then run a second rinse cycle. You might also try one of those specialized microfiber towel detergents that are sold through detailing supply stores. I just keep wondering whether the towels are the culprits here.
  • akimel
    replied
    Originally posted by Kevin Brown View Post
    Which car wash are you using? And... how much of it?
    If you are the type to "kick it up a notch" and add a bit more soap than is recommended, that could cause it. Some wash products have all sorts of goodies mixed in so help sheet water away, leave the surface slick, or even a bit protected. These ingredients need to be dispersed across the surface evenly, otherwise you're going to see the build-up where its thicker than the rest. This is one of those times that adding more is not a good thing. If you plan on modifying how much soap you're adding to your bucket... add less wash solution, and rinse the mitt & car often.
    When I first began all this, I relied on the volume markings on the side of my bucket. Then one day it occurred to me to confirm the accuracy of these markings. What I discovered was that these markings were wildly inaccurate. So I measured out the water, one cup at a time, and added my own markings. I also picked up a small two ounce measuring cup from the hardware store. Now I know that I am getting the right proportion between water and wash solution.
  • Kevin Brown
    replied
    As the others mentioned, if you use a spray detailer often, the "layer" of protection/beautifying agents could be a bit thick, and may be "floating" or is moved around by the towel as you dry (even if you're not dragging it).
    Finally, Al is right: if you haven't cleaned the paint lately, there could be oxidation present. The texture of oxidized paint could definitely hold onto all these "goops" that have been designed to beautify or protect your paint during and after washing.
    I agree with the others. I'd recommend that you wipe the paint clean, and apply a cleaner wax, or a polish and wax, to ensure that the paint is in tip-top shape (clay if you must beforehand).
    The next wash should deliver a much better result.
  • HealthyCivic
    replied
    akimel, I think you're on to something on #3... It's been a while and hopefully I will do it soon. It hasn't screamed out to me because I do keep my paint in relatively good condition... However, our water is extremely hard and I do know that I need to use a paint cleaner on it to remove some trace water spots that are mildly etched in. Thanks to you writing that, I realized that the paint will probably dry much easier after a thorough claying, cleaning, and waxing. I think those etched water spots may be doing that. In fact, that pattern that is shown in the streak may be where the water spots are... And what's interesting is I faintly remember this issue occuring several months after I last gave my car a big, fully involved detail.
  • akimel
    replied
    1) How do you launder your towels?
    2) This streaking happens both after quick detailing and after washing the car?
    3) When was the last time you cleaned the paint either with a cleaner wax (Cleaner Wax, ColorX) or a polish (SwirlX)?
  • CieraSL
    replied
    Are you using the Smooth Surface clay kit? Have you tried using the blue clay and LT or Final Inspection and wiping off? You could also just re-wash after claying, which is what I usually do. How often do you just QD the car?
  • Flash Gordon
    replied
    Try applying less product and fold your towel where it will have 8 sides
  • HealthyCivic
    replied
    I should mention too that thee photos were taken literally SECONDS after wiping... This isn't dried, it's just extremely stubborn to get off for some reason.
  • Shawn T.
    replied
    I always use two towels when QDing, one to spread, one to dry. It looks like you may be using too much QD.
    As for th washing, it could be soap on the surface but that one escapes me.
