Clear Mirror Reflection
  • Clear Mirror Reflection
    Hey all,
    I was wondering on how to achieve a very reflective image on your paint surface that is clear and not blurry. On my current car, I clayed it and there is somewhat of a mirror image but it is not clear at all. It is very blurry. After claying, I took some UC and tried to make it clear but that didn't even make the smallest of a difference.
    Any help would be appreciated
    Thank You
    Re: Clear Mirror Reflection
    You will probably need to post some pics and give us an idea of your application methods (hand/machine - how much pressure - pads used, etc)
      Not referring to orange peel are you?
        Car: Ford Mustang GT (Gray)
        Done by hand
        Pad: Meguiars Foam Applicator
        Moderate Pressure
        Whats orange peel?
          got pics? do you have any friends that might have a DA by any chance?
          polishing by hand with moderate pressure sometimes won't get the job done
            I'm gonna guess you have orange peel, which can be pretty bad on some vehicles. It looks just like an orange peel (rough surface) but on the clear coat, can make a nice reflection seem kind of fuzzy, which may get better depending on distance and angle. Only cure is to wetsand the clear coat smooth.
              Yeah, just do a little google image search for paint orange peel...
                Here's what orange peel looks like , it happens when the car is being painted. Poor technique, temperature etc etc
                This will have to be wet sanded to level it out.
                  Sounds like a bad case of orange peel.However pics would help out greatly.
                    Hey guys,
                    Sorry for the late response. I had my son take some pictures of the car and here they are.
                      One More,
                      Is it orange peel then?
                        Yup.
                          What should I do now to get it fixed?
                            Make it shiny and learn to live with it.....
                            Factory paint jobs dont have thick enough paint to safely remove it.
                            Think of it as texture....
                              It is generally not a good idea to "fix" orange peel on factory paint because the only way to truly correct the condition is to wet sand and then buff it out with a rotary buffer. The problem with that is:
                              • Wet sanding is a highly advanced technique that should only be done by someone with a lot of experience
                              • Rotary buffing, the follow up to remove wet sanding marks, is also an advanced process that should not be entered into lightly
                              • Wet sanding removes, potentially, a lot of paint. Rotary buffing as a follow up removes a fair bit more.
                              • Your factory clear coat is only about 2 mils thick - that is 2/1000 of an inch thick, which is as thin as it sounds.
                              • Virtually every auto manufacturer will tell you that removing more than 0.5 mil of clear coat will lead to premature clear coat failure. Ford recommends the removal of no more than 0.3 mils on their newer vehicles - that is 3/10,000 of an inch!!
                              • Your orange peel is deeper than any of this - do NOT attempt to wet sand it to remove or "fix" it.
                              Here's what you can do, however, to maximize the reflections in this paint:
                              • Clay the surface to remove all above surface bonded contaminants
                              • Remove all swirls, fine scratches, etchings, stains and other below surface defects with a D/A buffer (not a rotary, a D/A like Meguiar's G110v2 or the Porter Cable 7242XP) and something like SwirlX or Ultimate Compound (depending on how responsive the paint is)
                              • Refine the finish with M205 using a finishing pad on the D/A. You can work this product for quite some time and gain a lot of clarity to the finish
                              • Top everything off with a couple thin coats of NXT Generation Tech Wax 2.0
                              Medium to dark gray metallic clear coat paint can often look really deep and wet with the above process. The metal flake really pops with the above process and the finish takes on a level of clarity that is really impressive. Yes, the texture of the orange peel will still be there, but you won't mind quite as much!
