#80 + NXT Tech Wax
  • #31
    Hey,
    Acid rain is usually caused from rain that has a high concentration of H2SO4 (Sulpheric Acid). ( SO2 mixes with with water vapour (H2O) in the air = H2SO4) When the water evaporates due to the sun's magnifying effect, the concentration of acid increases, etching into the paint.
    Pinholes are usually caused from improper body work. Here is a link that may be similar to what you are seeing:
    Otherwise, I have not ran into any chemical overspray that was so strong to create pinholes.
    Any photos???
    • #32
      Tim, thanks. Maybe I shouldn't describe it as pin-hole. However, the paint surface has thousands of tiny holes on the clearcoat level - not all the way to the basecoat. I haven't got the chance to take a good photo of it, perhaps this coming weekend. Perhaps some really strong (concentrated) chemical landed onto my car and dried up under the sun. That's the worst damage I could imagine...sob sob
      zey's detailing photography blog
      • #33
        Hey,
        Rather than assume the worse, let's take a look at some photos first! It is difficult to judge a problem over the internet. But if you are able to take some photos, that would greatly help!!
        • #34
          Originally posted by zey
          Scrub, your formula is excellent! However, I need to add-in one more item into your formula, therefore it yields:
          Low RPM + Polish pad + Not too aggressive product + Light to almost no pressure + Watch How to Remove Paint Defects Video several times =
          I don't think it's easy to buff through the clearcoat if you follow the steps properly. Last time when I was a newbie, I tried to use a polishing cloth and Autoglym Paint Renovator to remove a bird lime etch mark, and guess what? It buffed through the clearcoat due to the concentrated pressure and excessive abrasive product being used.
          I will be sending my car to a Meguiar's detailing center coming weekend for paint correction due to industrial fallout/ chemical etching. After that I will take a photo of it...
          Your correct about the video. Got it and love it.
          • #35
            Tim, now I've recalled. Another possibility which causes the clearcoat failure might be due to insecticide overspray. What do you think?
            • #36
              Tim, I found this photo in Autopia and feel that my clearcoat has similar defect as what you can see over here. However, mine is more densed and evenly distributed.
              • #37
                Yesterday I spend 8 hours at the detailing center trying to restore the paintwork. Most of the pits and blisters are removed. Below shows the scope of work being done:
                1) Hyper Wash
                2) #85 Diamond Cut 2.0 with W-7000 (2-3 passes)
                3) #83 Dual Action Cleaner/Polish with W-8000 (1 pass)
                4) Hyper Wash
                5) #80 Speed Glaze with W-9000 (1 pass)
                6) NXT Tech Wax (1 layer)
                Some spots are lightly wet-sanded with 2500 Unigrit sand paper, and the gloss is restored by either #85 or Cut & Finish.
                Overall I'm very satisfied with their work.
                • #38
                  We appreciate your dedication in your pursuit of perfection!
                  • #39
                    4 passes of #83 with W-8006 @ 1500rpm on the left side.
                    My little collection.
                    • #40
                      Hey Zeytee,
                      Is that your practice target?
                      Nice shine on the toilet bowl....
                      • #41
                        meximum, oh yeah! I managed to crank it up to 1500rpm for the first time! #80 is unable to remove the haze on the plastic but #83 works like a miracle! To further remove deep scratches, the only way is to do wet-sanding. Perhaps that's the last thing I wanna learn in future.
                        • #42
                          Hey,
                          You polished the toilet lid?????
                          I am not sure what is worse, the fact that you polished the toilet lid or that now I am thinking about polishing mine as well!!!
                          • #43
                            Washed and applied #16 Professional Paste Wax on the roof, bonnet and C-pillars.
                            Very deep gloss, could see the depthness of the reflection especially the clouds
                            Still alot of orange peel problem after #85 Diamond Cut 2.0 compounding
                            • #44
                              Awesome roof reflections there
                              • #45
                                As usual, I'll take a photo, post up the pic when I get new stuffs. Today, I finally got myself a gallon of Hyper Dressing. I'm now waiting for the Hyper Dressing dispenser bottle to arrive next week and I shall start off with 3:1 ratio first. If it's too thick, I'll add more water, if it's too thin, I'll add more product. So versatile!
