Would the M80 Speed Glaze be OK to sue following the M105 compound? I beleive the M80 has the same abrasive level as the M205?
M80 to follow M105
Re: M80 to follow M105
Do a test spot and see if it comes out nicely. If it does, then you are good to go. Sometimes M105 won't even need to be followed up by another product, and there are even times when M80 or M205 need to be followed up (such as really soft newer honda paints)
Remove swirls my friends.
Originally posted by KaztheMinotaur View PostThanks.
What would follow M80 or M205?
As Andrew pointed out, on really soft paint you might need to follow up with an even lighter cleaner/polish such as M82 or M09, or even a cleaner/wax such as ColorX or M66.
You should be okay after the M205 or M80 step though. Just look over the car in direct sunlight or in really good lighting and see how it looks.Nick
What Nick Said! Remember though, it is very rare that you are going to need to ever follow up M80 or M205.
M205 doesn't necessarily need to be worked as long as M80, because in M80, you need to break down the diminishing abrasives in the product, where in M205 they don't need to be broken down. You can do 1 pass of M205 and if it works, then you are good to go.
