How to use UQD
  • How to use UQD
    I feel the each time i use it im added sratchs/swirls to my paint. When i mist and whipe, i can see the dust on the mf towel (oviously brown splotchs), when this happens to i have to get a new towel? i mean i cant whipe my paint with the areas with the dust not on it correct?
    Re: How to use UQD
    When you do the initial wipe with the microfiber it is pretty effectively pulling the dust/dirt into the towel and you can, within reason, use that side of the towel on another panel. If you fold the towel in quarters you effectively have 4 pairs of sides to work with as you go around the vehicle. Whether you need to use a second towel depends on how dirty the car is to begin with, how scratch sensitive the car is, etc.
    Read through this thread - you can wipe down a vehicle on a regular basis without inflicting any real damage. The paint sensitivity will play a role, no doubt, but if you're careful you can use this process regularly without issue.
      Re: How to use UQD
      UQD is all I use to clean my car. I never let it get too dirty but even with moderate amounts of dirt I haven't had any problems, the detailer seems to do a god job lubricating the paint and the microfiber traps all the dirt. Just use plenty of the stuff if you have anything more than a light dust on the car.
      I will usually use about 4 or 5 towels to do my car,but more because they get saturated with detailer.
      If you are worried about it why not just get plenty of towels and do a small section with each initially, after that the key is to never let it get too dirty and you will be able to use the same towel longer and it will go easier.
