which would be more efficient for removing swirls? one of those cheap orbital buffer with soft foam bonnet with DC cleaner or scratch X by hand?
orbital w/ DC cleaner vs scratch x?
Re: orbital w/ DC cleaner vs scratch x?
You could try the cheapie orbital with the ScratchX as it is much more effective at removing below surface defects versus the Deep Crystal Paint Cleaner which is a chemical cleaner only. However, be aware that the ScratchX can become gummy and hard to remove when heated so as long as you using a cheapie orbital which tend to be fairly slow, it might work for you.
thx for the quick reply
yah ive been able to get very good results with scratch X in swirl removal but its just takes so long on just one section.... so i was wondering if i can use anything w/ the orbital in the garage to speed things up
If you want to use a machine to remove swirls, try MPPC. It can be either used by hand, orbital or PC. MPPC works great with the PC and it should do a good job with the orbital too.
Another option, and one that I really like, is using #80 Speed Glaze, it can be used with the orbital or PC plus it adds polishing oils too, so it can be a great time saver. Also, #80 is easier to find locally, the PBE dealer stocks it whereas they don't stock MPPC.
I wish I would have tried #80 earlier! The PBE dealer said it is one of their most popular products.
Mike, is #80 considered to be more or less aggressive than MPPC?
RamAirV12015 Dodge Charger R/T Scat Pack 392Granite Crystal
2006 GTO Impulse Blue
What Tim said. MPPC is very difficult to find locally, but most PBE stores will have #80 or can get it for you in 1 or 2 days from their distributors. You could always order MPPC direct from Meguiar's. If you have any NAPA stores in your area they may have the MPPC.
