Swirl X or M205
  • Swirl X or M205
    so my DA polisher is comming 2morrow. With a set of pads. Working on new vehicals. Is swirlX the same as M205? or is 205 a lil less aggressive? Can i use M205 regulary?
    Re: Swirl X or M205
    Not sure if they are the same or not, but I'd definitely recommend M205. You can use it alot since it has a cut rating of 4/12 and it's a remarkable product. Brings out more clarity, depth, and shine than any other product I've used. Has decent cut as well if you use it with cutting or polishing pad.
      Re: Swirl X or M205
      Thanks. looks like ill be gettin some 205 and ur stang looks AMAZING!
        Re: Swirl X or M205
        Thanks Be sure to post pics of your experiences and don't get frustrated - it takes a little practice and experimentation to get the technique down, but once you do, you'll be breaking into your neighbors garages to polish their cars LOL
          Re: Swirl X or M205
          haha. probably. What do u think is the best way 2 start learning? My step mom has an 2003 Pontica Montana. So i might start on that. It is really neglictated but is kept in the garage? lol we also have 3 2008s and a 2009. can i mess something up wit 205 or waxes? prob not right? how did u learn???
            Re: Swirl X or M205
            Try both on the trunk or some other surface where you can do a good 50/50 test. Look at each side, see which one looks better, and use that one
            -Kyle
              Re: Swirl X or M205
              okay. nxt week i will post some pics of her ride and see what yall think is best? look for the post nxt week! ITS REALLY BAD! not faded just deep scratches.....i kno i cant fix some of them but i can def make a difference at least thats my goal
                Re: Swirl X or M205
                You may need to try ultimate compound or M105 if the scratches are that bad since M205 and swirlx are more for milder correction.
                  Re: Swirl X or M205
                  If you are doing light polishing, then use the M205. For oxidation or heavier scratches, you may need M105 if M205 doesn't cut it.
                  I learned on my '88 Mustang with less than perfect paint:
                  Amazing how easy M83 is to use with the right technique! (http://meguiarsonline.com/forums/showthread.php?t=23577) Some of you may have read the thread I posted a week or two ago called "PC 7424 first use - what am I doing wrong?" With some great tips and advice I was able to get some decent results using
                  The same principles I mention in the writeup for M83 apply to M205 as well or any other polish or compound for that matter.
                  Good luck!
                    Re: Swirl X or M205
                    SwirlX is more aggressive than M205.
                    Aggressiveness Order for New Consumer Products - This will surprise you!
                    2013 Highlander - black
                    2010 TL - black
                      Re: Swirl X or M205
                      If that's the case then M205 may prove to be too mild for your situation. SwirlX and Ultimate Compound may serve you better on this vehicle, but the paint itself (how hard or soft, etc) is going to be the ultimate decider. But from this description, Ultimate Compound would seem to be the better choice.
                        Re: Swirl X or M205
                        WHat does a "cut rating of 4/12" mean?
                        2010 Camaro SS RS (black), "OBSSEST"
                          Re: Swirl X or M205
                          It means on a scale of 1 to 12, with 12 being the most aggressive, M205 is a 4
                            Re: Swirl X or M205
                            Interesting. Is this an "objective" scale, such that another polish manufacturer would have a product that is also a 4? Or is this a scale amongst Meguiar's products like the chart that has been posted here and there?
                            What is the cut rate of Ultimate Compound?
                              Re: Swirl X or M205
                              It is relative to other Meguiar's products. Check out this link:http://meguiarsonline.com/forums/sho...threadid=10662
                              While the chart is a little dated and doesn't list some of Meg's newer products like UC, between it and Aggressiveness Order for New Consumer Products - This will surprise you!, you should be able to get some idea of where UC would fall.
                              2010 TL - black
