Clay questions
  • Clay questions
    Can some one tell me the difference in the clay in the smooth kit, the pro line mild and pro line agressive?
    Re: Clay questions
    This is from another thread:
    Originally posted by mattaleca View Post
    Why can't you use the Mild Clay as often. I realize that the Aggresive will haze and Micro-mar the finish but shouldn't the Mild be safe to use monthly, daily, hourly, etc.
    Regarding regular use of the C2000 Mild Detailing Clay - while it should be just fine for regular use, most people don't want to spend almost $30 on clay alone, plus if you're claying regularly the amount of bonded contaminants should be very light anyway, so the consumer clay should be sufficient to remove it. But if you prefer the blue mild C2000 clay there shouldn't be any problems using it regularly. Is it removing more wax than the consumer clay? Ah, the $64,000 question! When is the last time you waxed - how much wax do you really have left on the car anyway? If you're getting a lot of contaminants bonding to the paint, you're either exposing the car to a lot of crud and/or not waxing and maintaining the finish as often as you might. Of course there are always those unforeseen circumstances like parking downwind from a building being spray painted, but in that case you need some serious claying anyway.
    And red should only be used if you have unusually rough paint and are planning on polishing afterwards anyway. For Joe Blow, the consumer clay should be enough.
      Re: Clay questions
      Great question. I was just pondering this earlier in the day.
      Click for more pictures of my tC
        Re: Clay questions
        That does not really answer the question as to what the difference is between the white consumer clay and the blue mild clay. I'm guessing the blue might be slightly more aggressive then the white?
          Re: Clay questions
          The blue is slightly more aggressive than the consumer clay, but not by much. You can use either one without fear of marring your paint, as long as you are using plenty of lube. The blue is geared toward high volume detailers, who go through lots of product and so they need to buy in bulk. It is usually cheaper to buy in bulk as well. A professional detailer does not want to run down to Wally World and pick up 10 Smooth Surface Clay kits so he has enough clay for that month or week or whatever. So, you can go with whichever one you like. I use both with no problems.
