removing seats to clean
  • CieraSL
    replied
    Re: removing seats to clean
    Originally posted by jpierson View Post
    Not the same thing. You need the blue tube.
    Darn. Well, looks like another trip out.
  • jpierson
    replied
  • CieraSL
    replied
    I went to Wal-Mart, and I couldn't find the little blue tubes, so I got this:
    Will this work, or do I have to have the little blue tube?
  • G_S_DB
    replied
    One note about Lock-tite. I read that you should never touch the tip of the tube to the metal of the bolt. The article talked about a chemical reaction between the ions that would render the liquid in the tube ineffective. It sounded like sound advice, so just maybe just somehthing to keep in mind.
  • Nappers
    replied
    Looks like you're going to have fun with that Honda. Kudo's to you asking, better to be safe than sorry.
    I believe, and already mentioned is more than likely the seatbelt sensor. Unplug and remove the seats
    Loctite can be found at most if not all auto stores, hardware stores and Walmart carries it as well. It's really cheap too, 5 bucks or so. More than likely it's "blue" loctite and just put a drop or so back on the bolts and torque them down when you put the seats back in.
    Can't wait to see the finished product!
    I used APC+ and Quik Out Aerosol can for interiors and some terry towels and a bucket of water for rinsing!
    You can scroll through these threads I did on interior work if you haven't already.....
    Dodge 2500.....
    2005 Dodge Neon.....
    I like interior work.
    Keep us posted!
  • CieraSL
    replied
    Obviously with the front seats out you will also be able to clean underneath the seat better as well as the surrounding area. Should be interesting to see how dirty it is.
    It's kinda nasty. I pulled the center console apart fairly recently just to see if I could (), and there was what looked like corn flakes and cheerios under there. Yucky stuff. I haven't really done any cleaning on it yet, so I'll get some good before pics. The rain channel in the trunk is nasty too. Nothing Meguiar's can't handle. The reason I want the seats out is because there's some old gunk down in there that I don't think I'll be able to get if I leave the seats in. I have crevice attachments for the vacuum, but I need to really be able to get in there. I'm looking forward to it. This will be my first time pulling an interior apart, so this writeup may be a little more extensive. Fun stuff!
  • the_invisible
    replied
    This has probably been mentioned, but the cord underneath is for the seat belt sensor.
    There's no airbag sensor, electric motor, or heated seat on this year of the Civic. When working with a seat with an air bag sensor, disable the airbag system before unplugging any of those plugs.
    One thing that seems to be quite common is that the thread in the bolt hole would strip if the bolt is not inserted properly during the installation process. I find the seat anchor line up with the threads quite easy, but I always read on the internet that people strip the bolt holes while tightening the seat anchor. That's something to be careful with. Always tighten it with extremely little torque to ensure the anchor bolt is seated properly with the thread.
    Cleaning is very straight forward otherwise.
  • Tuck91
    replied
  • cnfowler
    replied
    No problem. I look forward to the pictures when you're all finished.
    Colin
  • CieraSL
    replied
    Shane, what JohanD said.
    The one wire is your seatbelt sensor.
    Read this:
    http://hondaswap.com/body-exterior-i...-civic-119568/
    Thanks! That really helps!
  • JohanD
    replied
    Can you buy it at Lowe's or Home Depot? What area of the store should I look in?
    Yes, lowes or home depot should have it. I would go with the blue, as cnfowler suggested.
  • cnfowler
    replied
    You should be able to find it at one of those. I'd go to the fastener section first and ask one of those guys. The blue locktite is recommended since the red locktite is considered permanent.
    Colin
  • cnfowler
    replied
    Read this:
    I had to do this for some credit in school, so I figured I might as well post it here. I know that when I was going to do my seat swap, I wanted a write-up to look at, even if it was a really simple swap to make. So hopefully this helps someone...
  • CieraSL
    replied
    Originally posted by JohanD View Post
    Locktite is a liquid that you put on the threads of screws and bolts. When it dries it really secures the screw in place. There is blue Locktite that can be removed by hand tools, and then red locktite which is stronger and requires power tools. The cost is pretty low, maybe $5-$10, and can be bought at most hardware stores.
  • JohanD
    replied
    Pardon my ignorance, but what is Locktite? What does it cost, and where can I buy it?
    EDIT: No, the seats do not have power lumbar support. Nothing on the seats is power. What is that one wire for?
    As a side note this also works great as a form of plumbers tape as it fills all the gaps. I use this to make air tight connections on my paintball gun.
