products that shouldnt freeze
  • products that shouldnt freeze
    I noticed on the back of a few products they say do not allow to freeze
    does Meguiars put this on all products if necessary?
    just wondering for winter storage this year what I should not leave in the garage, thanks
    Re: products that shouldnt freeze
    You should try not to let any megs products be exposed to freezing or high heat temps as this usually causes the products to go bad. For example pastes waxes may separate and you may see a mush of wax and some liquid inside which is not normal as paste waxes should be hard/pasty.
      if you have a situation such as an outside shed that can reach freezing temps, i would box it up and bring it inside for the winter. CT can get above 100 and below -20 degrees in a year.
        My garage is pretty old so I wouldn't say it keeps the cold out pretty well. The lowest temperature around where I live gets close to -10 C, ( 10.4 F I think ) The garage probably will not get that cold but just to be safe, is it OK to leave my products in the garage or should I move them all inside?
          Freezing, definitely is a no-no. Never let the products freeze. Bring them inside for the winter.
