M135 Synthetic Spray Detailer
  • M135 Synthetic Spray Detailer
    Can i use the M135 to prime a new pad before polishing with M105 or M205?
    Is it any difference if it is a wool pad or foam pad?
    Thanx Eric.
    Re: M135 Synthetic Spray Detailer
    No I would not use #135 to prime a pad. Stick with Last Touch, Final Inspection, or in a pinch the regular qd.
      Hello again.
      right now i dont have the last touch or final inspection from meguiars.
      But i do have a product thats called final touch, not meguiars, that contains isopropanol, and is made for a final wipe after polishing, prior to Last step protection.
      It kinda removes all the remaining oils from the polish and dries very fast.
      Would that product be ok to prime a pad with ?
        Eric, check this out...
        A look into Pad Priming - The Kevin Brown Method Hey everyone, I thought I would give you guys a little sample of Kevin's paper. One of the most important topics covered is pad priming. Although it may seem simple, I wanted to clear up some confusion. When I refer to pad priming, I am referring to the liquid that will
        This will probably be the most effective way to prime your pads.
        Hope this helps ya!
        Wife say's I'm "obsessed"!
          thanx thats how i do it today, i got a bit confused about the whole priming part .
          so thanx again for clearing that out
            Hope this helps ya!
            Just to note that this is only recommended when using products with SMAT. You are fine because you are using M105 and M205. But people reading that would like to use M80 or any product with diminishing abrasives this is not the way to prime
