What quick detailer do you recommend that has good cleaning ability? I have ultimate QD and it does a great job at leaving a nice shine but Its not the best at removing water spots. Would you recommend Last touch or Final inspection? Any feedback would be much appreciated!
Good cleaning QD
Re: Good cleaning QD
Might need to wash the vechile to remove the water spots or if etched in you may need to use a paint cleaner like SwirlX or ScrtachX 2.0
try washing them first and see how that works.Nick
You mean the fresh water spots from the wash are not being removed by UQD? That is curious.
A lot of us use Last Touch as a drying aid precisely to remove car wash water spots. Spray on some each panel as you dry. You should find the fresh water spots removed.Swirls hide in the black molecular depths, only waiting for the right time to emerge and destroy your sanity.
--Al Kimel
Yes, fresh water spots from a wash. It will remove the spots, but it takes alot of effort. I find that I have to go over each area a couple of times and I have to use more pressure with my microfiber than I am comfortable with. Just wondering if Last Touch or Final Inspection would do a better job. I have used other quick detailers and didnt have this issue.
How-to Wash your car with a Rinse-less Wash System [video]
you could try the rinse-less wash system demonstrated by "Mark Kleis" with Last Touch and a Wash Mitt...
but if your water spots are caused after a wash, it could be because the conditioner you were washing the car had dried out.. I find that sometimes when I wash in really warm weather... :]Ganesa,
Toyota Vios '05
Years ago I worked for a Limo company that used a similar method to wash the Limos . They would take a bucket of water and a mit , they would spray a panel with QD, and then wash with a wet mit and then dry with towels.It worked great at the time. Of course if the limos were very dirty they would use a hose.
2006 GTO Impulse Blue
Originally posted by Ganesa View PostHow-to Wash your car with a Rinse-less Wash System [video]
you could try the rinse-less wash system demonstrated by "Mark Kleis" with Last Touch and a Wash Mitt...Success is never final, failure is never fatal. It's courage that counts.
by John Wooden
'88 Honda
