problems with NXT.2
  • problems with NXT.2
    I recently bought NXT.2 after glowing reports about how great it is. I tried it and used the same steps that i have used with Gold Class past wax. The NXT leaves a film that is tough to get off. I have used small areas and large areas. I have waited a few minutes and have wiped off immediately. The same problem exists. Any suggestions?
    Sleepy
    Love the Classics!
    Re: problems with NXT.2
    i think it's time the community calls for NXT 3.0, one that doesnt streak please
      No issues here with my NXT 2.0 liquid.
      Are you applying it very thin?
      Are you making sure your car is well-prepped? (Washed w/ Gold Class/NXT wash)...no residual polishing oils on the paint prior to waxing...etc.
        Yes on applying thin layer, crystal clear car wash, I have clay bared, m80 because it only needed a light correction, I waxed it in the shade with the purple applicator. I have used a high cotton fiber towel to take it off. Could there be a difference between liquid and paste that I do not know about. By the way, WHEN I did get it off the sections that did not have the dark film on it, looked FANTASTIC!
        Sleepy
        Love the Classics!
          I've had no problems with the liquid version. I also have the paste, but haven't used it yet. I hear that paste-type wax is generally a little more difficult to remove (because it's "harder"?). Did you rewash your car after using M80? That could do the trick.
          I also use a simple twice-folded MF cloth to remove wax. I forget what they are made out of, but they work fine.
            Sorry I also have never had any issues with NTX 2.0. It is my favorite and the easiest to remove. Dont know what to say.
              How long did you allow NXT to dry before you removed it?
              Given that you applied a thin coat, the most plausible explanation is that it was not given sufficient time to set up properly. Depending on ambient conditions, it may take up to 30-45 to dry.
              Did you do the swipe test? Are you sure the wax had dried?
              --Al Kimel
                That's the first thing I was thinking. I've used NXT 2.0 on surfaces I wish I would have had the time to clay and it still turns out ok, so I don't think that is your problem. I think it's just the time you are letting it (not) set-up. I typically put the coat of wax on the whole car, done a few other things like cleaning up or the interior and then swipe test where I started and it is usually a good 30-40 minutes and it will be ready.
                Here is the link to the swipe test thread: http://www.meguiarsonline.com/forums...&threadid=2166
                Keep us updated on your progress.
                "Difficult takes a day, impossible takes a week." Jay-Z
                  No issues with the paste NXT, didn't try the liquid yet though
                    I don't have a problem with either paste or liquid NXT 2.0...
                    It works fine, even on barely prepped paint.
                    I wouldn't mind some NXT 3.0.
                    Daily - 09 Chevrolet Colorado - Techno gray metallic
                    baby - 92 Chevrolet Caprice Classic - aged, yellowed, white.
                      I did the swipe test, and it just smeared. The thing is I used it on my '64 belair with a single stage paint with no problems. Dry time was a few minutes.
                      Sleepy
                      Love the Classics!
                        A few minutes drying time is probably insufficient, given the problems with smearing you are experiencing. I recall a post in the archives by Tim Lingor in which he stated that the Megs' chemists recommend 15 minutes. On the other hand, others have found that sometimes, depending on variant conditions, waiting as long as 30-45 minutes is necessary. Try a longer set-up time and see if the resolves the smearing.
                        --Al Kimel
                          Update, It was about 15 to 20 minutes and NXT.2 came off fine. Thanks for the help Guys! I just need a DA so do not have to work so hard!!
                          Sleepy
                          Love the Classics!
                            One of our members just offered this advice on another forum about NXT and drying time. It makes good sense to me, given the problems some folks have with smearing, so I thought I'd pass it on: Do the swipe test. If the wax swipes clear, WAIT 15 minutes and then remove the wax residue. My guess--and it's only a guess--is that this will eliminate 99% of smearing problems.
                            --Al Kimel
                              another NXT problem solved :]
                              Ganesa,
                              Toyota Vios '05
