Questions on hood
Re: Questions on hood
The foam cutting pad is NOT recommended for the D.A.
And the least aggresive method should still apply. Are those white paint specs on the hood, some seem to big to be rock chips."Every moment frontin and maxin
Chillin in the car they spent all day waxin"
What all do you really have going on with this hood? Is that a scratch down to the primer? Are the spots chips, sap, or something else? What all have you done/tried thus far?Michael Stoops
So it's just the dried tree sap you're really struggling with then?
This quote from Kevin Brown was found in another thread, but it should do the trick for you:
Originally posted by Kevin Brown View PostI would recommend that you do a complete wipe down of the car using Meguiar's D120 Glass Cleaner Concentrate.
I would mix it stronger than the recommended 10:1. This product contains alcohol (as well as other ingredients) that will remove any dried on or fresh tree sap. It really is incredible to see!
You can mist it on small sections (1'x1'), let it sit, then wipe with disposable cotton towels. If there are any stubborn remnants, simply saturate a small rag with the concentrated glass cleaner and place it over the sap until it loosens its bond (use anything from 1:1 to 3:1 water/glass cleaner as a starting point).
You certainly don't want that stuff melting into your buffing pads or onto the paint should you decide to buff the car... which you may need to do if the sap "stained" the paint (read that to mean damaged, dissolved,or etched).
I would wish you good luck but you won't need it because this really works.Michael Stoops
