Originally posted by Show N Tell
View Post
A warning on "paint wrinkle"!!!
Re: A warning on "paint wrinkle"!!!
What do you recommend for plastic bumpers when using m105/205?
Originally posted by Mary S View PostRasky, I really appreciate your posting this, because it could have easily happened to me in the upcoming days.
It kind of sounds like the most conservative thing to do with plastic bumpers if you are going to buff them is to use a rotary with a 4-inch pad; unlike the DA, which is more aggressive with a smaller pad, the rotary is less aggressive with a small pad, because the outermost part of the pad moves at fewer cm/second than with a larger pad at the same rotational speed. Still, caution is needed, because it sounds like the paint on the flexible bumpers doesn't adhere as well as to metal.
Originally posted by RaskyR1 View PostThank you.
I still find myself using the rotary on heavily swirled bumpers, but I'm definitely more cautious now and I'm always checking to make sure the panels are not getting warm/hot.
Rasky
I often wonder how much of this flex agent is in the paint on my polymer panels.
Originally posted by Mark Kleis View PostHmm, I know that twice doesn't make a pattern, but I wonder if it is something to be more cautious of with Honda paint.
I was thinking the same thing Mark. Rasky was working on a Honda, so was KerrinJeff, and the post by benedict was an Acura, which is made by Honda.
I know from working with Hondas before that their paint typically tends to be pretty soft, especially with some of the newer models like the Fit.
Like you said Mark, twice doesn't make a pattern, but I'm just wondering if the typical delicacy of the Honda paint, plus a plastic bumper and just a little bit of heat is all you need to get this?
The pontiac in the autopia forum was in the sun, so the heat from the sun probably added to his issue.
I have a spot on the hood of my Astra that looks very similar to this, just not wrinkled. It looks like the paint just sort of broke, like a window. I'll take a picture today when I get home and show what it looks like.
At first, it looked like an etching. I polished it, and the etching went "away" and sort of turned into this. But it's on the hood!? I'll have to post a picture to get a good answer, but do I need a respray? Great...
Originally posted by Garage Troll View PostI just saw this thread and wanted to make a comment. Rasky, thanks for the post and warning. It really is a rare trait nowadays for someone to step up and say "oops, look what I did! Watch out everyone!" I for one would trust you with my baby any day.
Thank you.
Rasky
Paint wrinkling sounds like a classic paint adhesion problem on plastic substrates. In addition to flex agents, its very common for adhesion promoters to be used when painting plastic substrates.
Too make things more complicated - auto manufacturers use different types of plastics and often the adhesion promoter is optimized for a specific plastic / paint combination.
Bottom line - be careful polishing painted plastic parts.
Rasky was using a rotary in the original post to this thread, but don't think for a minute that this can only happen with a rotary buffer.
As kerrinjeff mentioned, he experienced this using a 4" cutting pad on a D/A. That combination can be quite powerful since using a 4" pad on a D/A concentrates all the energy into a very small area. If you then run the tool at fairly high speed, use heavy pressure and a cutting pad, it is amazing how much heat you can generate with a D/A. Dwell on one spot for a bit longer than usual and you really increase the chances of this happening.
There is definitely something going on with the paint used on these flexible bumper covers. Whether it's the flex agent added to the paint causing the paint to be a bit more delicate, or whether it is some how compromising the bond of paint to panel isn't 100% clear. But exactly what is causing this less important to a detailer than the fact that the situation occurs at all.
When working on these areas just be extra cognizant of the area you're working on. This substrate does not dissipate heat the same way steel or aluminum does. And while we don't normally think of a D/A as creating a lot of heat on the paint like a rotary does, it certainly can in this case (4" pad, cutting pad, pressure, speed, dwell time) and it can bite you before you know it.
Used properly, both a rotary and D/A are perfectly safe on these flexible panels. But a little higher level of caution or awareness here is definitely a good idea.
Originally posted by Brook View Post
Does this mean it can't happen if using a DA?
http://meguiarsonline.com/forums/sho...6&postcount=15
Originally posted by Fly Bye View Post
Is the fiberglass flexable?
My bike has plastic panels, and I've never had a problem with cleaning/polishing them as they are pretty firm/sturdy.
Originally posted by kerrinjeff View PostSame exact thing happened to me, also on a Honda, except using the PC with 4" cutting pad.
I used a rotary quite extensively on bumpers and have never run into this, but like Rasky said, it can happen to anyone, anytime.
