Clay Bar Prep Question - Does wash-Wax solution hurt?
  • Clay Bar Prep Question - Does wash-Wax solution hurt?
    I use a Turtle Wax Wash-Wax solution to wash my car and I was wondering if washing my car with this soultion before I clay bar it would hurt the effectiveness of the clay bar since it does have a bit of wax in it or is it not enough wax to matter?
    Re: Clay Bar Prep Question - Does wash-Wax solution hurt?
    It should be fine.
        No problems,wash then clay.
          Wash then clay. You should be fine.
            Any reasons why I never seen any pros recommend wash-n-wax, for regular washes in-between waxes ?
              My feelings on a wash-n-wax product is that they are kinda contradictory. A wash is meant to removing all impurities sitting on your cars surface and not put a layer of protection on. Most of the time the car wash will only work decent and the wax is almost non-existant. It doesn't make sense to have a cleaner mixed with a protectant....
              Remove swirls my friends.
                I agree with Andrew C. The wax left behind is bare minimum. If anything, claying the finish after a wash/wax would probably remove that very bare wax coating anyway. Using a wash/wax should never substitute using a proper wax application as a separate step in maintaining your finish.
