I have settled into a routine of rotary/M205/yellow polishing pad and DA/M205/black finishing pad for most of my work with the occasional rotary/M105/solo wool light cutting pad for more aggressive work. I'm in love, and I want to refine my technique, but....
I'm a little confused about arm speed and work area. I can't afford to waste time on a detail job over-finessing the paint, nor can I afford to spend a whole weekend on my car or spread the job out over 3-4 weekends when I have a wife, kid and house to take care of as well.
With the rotary, I find myself using for any product the rate of about 10-12" per second in open areas, or maybe 6-8" in cramped areas. I usually go twice in each direction, overlapping passes by 50% and slowing the machine speed down for the last pass. I work an area about 24" squared, or maybe 12"x36".
With the DA, I tend to move more like 4-6" per second. I have only used the DA with a finishing pad and M205 to knock out rotary holograms and not any serious paint correction. The arm speeds I've seen posted have been around 1-2" per second, which seems like a snail's pace to me and would take like 4-5 hours per pass around an average vehicle! I usually work an area about 18-24" squared, or a little smaller than the area I would polish with a rotary.
Any suggestions? I've been getting stellar results on the last couple details. I just did my Altima on Saturday and used these arm speeds and work area that I mentioned, sometimes fast arm speed and bigger area in some cases, and got results that easily surpass what I've seen before.
I have the DA polishing video with the black Corvette and pretty much follow that technique, though I tend to move faster and work bigger areas.
With the SMAT products, have people been finding that they've changed their arm speed or work area?
I just want to make sure I'm not wasting any time, or worse, moving too fast and sacrificing even greater results, though I'm having a hard time picturing that after 5 years owning a DA and 3 with a rotary. The depth of gloss and reflectivity I'm getting are beyond what I've ever gotten finishing with the DA. I used to have to finish with Scratch-X all the time because M80 left micro-marring on most cars I buffed. With the same process and using M205 instead, no problems.
Any full-time, pro, experienced detailers in the Minneapolis area that could watch me sometime for an hour or two and see if I'm being efficient and effective?
Thanks!
Thanks!
