Project Alfa, Below Surface Defects
  • Project Alfa, Below Surface Defects
    Just pick up a '88 Alfa Romeo Spider. Red color, single stage paint. So far I washed and clayed the car. Then I did a test spot with my DA polisher, polishing pad and M80...did nothing to the improve the imperfections. So I repeated the process, again nothing. Then I switched to a cutting pad+M80...again nothing. Hmmm.......
    So I pulled out the 1st generation M105 and the cutting pad and I got some results. After all the M105 work, I followed up w/ M205 and a polishing pad the waxed w/ Nxt tech 2.0. I was working in my garage and the lighting was decent. However, I was taught to use 2 different light sources...so I did. When I rolled the car back to be under direct sunlight....I was pretty dissapoined that the below surface defect (water etching) marks were still there!
    Not really sure what the next step is here. I threw the swirl killer M105 at it and I still have defects. This may require some advanced techniques, (ie. wet sanding, rotary buffer).
    PLease advise.
    Re: Project Alfa, Below Surface Defects
    Well it sounds like your on the right path
    You might want to try it again
    You need to get a good light sorce so you can see what you doing to your paint
    Here's a Swirl finder-
      You think that I should hit it again with M105 and the cutting pad?
        • Try M105 with the cutting pad
        • Work a small section, about a foot squared. Keep your work area small while you're in the testing phase.
        • Use the 5.0 Speed Setting
        • Push down as hard as you can while holding the pad flat to the surface but make sure you're still maintaining a fairly fast clip of speed for pad rotation.
        • If you have not marked the back of your pads then place a mark on the back of the pad and/or backing plate so that you can more easily see that the pad is rotating.
        Work your section using the above tips and if you're still not seeing the Type II Water Spot Etchings coming out then you'll likely need a rotary buffer.
          I'll put a little more passion behind the DA.
          Only used the rotary in the advanced techniques class. I have to say that I'm still a bit nervous with the rotary...actually don't even have one yet. Might be time to step up....
            Rotary buffer indeed!
            Paint was swirled, oxidized and stained with water spots.
              Most of the car was single stage paint as the wool pad pulled color fromt he paint. Some parts were clear coat base coat.
              Hows this for a businessman, I recruited the customer to polish!
              With little direction form me he was polishing up a storm.
                I continued on with the rotary/#105 as Sevag chased me with the G100 and #205.
                  A light rain started to fall so we pulled the car into the garage for a coat of wax.
                  Dual xenon light picture -
                    Here are a few outside pictures.
                      Nice work on the Alfa!
                        Only one comment from you guys!!!!! Car came out really nice.
                          It isn't in the show off your detail section.
                            Nice job!
