• Spooky Halloween background with an assortment of Meguiar's products, Halloween Big Sale, 15% off with code HALLOWEEN, expires 10/31/24 valid online only, excludes discounted kits.
bought a polisher
  • bought a polisher
    Harbor Freight buys their top quality tools from the same factories that supply our competitors. We cut out the middleman and pass the savings to you!
    I know is cheap, but will it do the Job??
    http://www.nitrousworld.com/pictures/newlogo.jpg
    It will do the job.
    Are you familar with a rotary buffer?
    What do you intend to use the polisher for?
    Eric
    Talk it over folks. Communication is the key.
    --Jerry Springer
      Re: bought a polisher
      Originally posted by ilanpro
      http://www.harborfreight.com/cpi/cta...emnumber=46507
      It should for a while at least...
      Under constant, heavy use like a full-time detailer or someone who works in a body shop, it might give up sooner than more expensive models. (You get what you pay for). For the weekend-warrior it might hold up however.
      Here's an idea...
      People are always asking, "How do I clean my foam pads", (in reference to the foam pads they are using on their G-100 (PC). One of the best ways to clean a foam pad is to clean it using a rotary buffer. There are two ways, one is to hold a terry cloth towel into the foam while bringing up the RPMs and absorbing excess liquid out, the other is to hold a nylon brush against the face of the foam pad while bringing up the RPMs, this will remove excess product also.
      So instead of thinking of an inexpensive rotary buffer as a rotary buffer, think of it as an inexpensive Pad Cleaning Tool.
      Just an idea....
        Re: Re: bought a polisher
        Mike,
        Why to think outside the box.
        Eric
        --Jerry Springer
          Mike, you're always surprising us!
          ilanpro, throw away the backing plate and pad comes with it! Otherwise, it is a surprisingly good tool.
          I actually just bought a second one (the first is 18 months old!) I leave one with with a big honkin wool cutting pad, and one with a smaller backing plate for 6" foam pads. Saves time by not changing backing plates...
          My Fein rotary is the 'goto' tool, however.
          If it was easy, everybody'd be doing it!
          www.jimmybuffit.com
            I want it for pesonal use, What kind of pads should I use to get rid of swirls??
              I want it for personal use, What kind of pads should I use to get rid of swirls??
              Depends on how deep the swirls are. Swirls are simply scratches in the paint, so when you think of removing swirls, think of removing scratches and which products and pad you use to remove swirls depends on how deep the swirls are.
              For light swirls, you can use #9 with our foam polishing pads. For medium swirls you can use our #83 with our foam polishing pads, for heavy swirls, you may have to use our #84 Compound Power Cleaner with a foam cutting pad and the re-buff the area with less aggressive cleaner/polishes.
                It's on sale in Harbor Freight stores for $30. I don't know if HF.com includes shipping in the $25 price but if they do not, for $30 it should be just as cheap (if not cheaper) with shipping.
                I don't know if they will price match to the online price in stores because, well, I asked for it for x-mas from my mom.
                  Here's an idea...
                  Just an idea....
                  I tried that with the PC and it did not work so well. It seems like the PC stops spinning when I hold a nylon brush against it. Scrubbing with the PC turned off seems to work just as well.
                  RamAirV1
                  2006 GTO Impulse Blue
                    I have that exact same harbor freight buffer/polisher bought it back in june used it 3 or 4 times and now it doesn't work. Don't know what happend but when you are using it it wont stay at one speed, it keeps speeding up and slowing down I checked the brushes and they were fine. But anyway, It lasted me a few months and the way I figure it's only $25 bucks if you have to buy a new one, but I have a porter cable coming for christmas. Just my .02
                    Nothing but the best, That's why I use Meguiar's.
                    1996 Lincoln Mark VIII LSC Dark Baltic Blue
                    4.6 32 Valve DOHC V8
