Re: M80 as a paint cleaner
#205 is a cleaner/polish, but not sure if it has as much as #80.
I can't wait to get my hands on some M80 for the SS paint on my Cutlass and my friend's Plymouth. From what I understand it takes care of light oxidation while giving a deep, glassy shine.
Originally posted by Mike Phillips View Post... the M80 is abundant in polishing oils so that as long as it's finishing out well on the paint system you're working on, that is no micro-marring or hazing then you could go straight to wax.
Originally posted by Black Bart View PostI think M80 was designed for single stage paint.
I was told it was targeted for auto auctions where there was a need for a product that would work on anything, could be applied using a rotary buffer to quickly restore the shine to a abused or neglected surface with easy, fast wipe-off.
Keep in mind that the goal for cars buffed out for wholesale auto auctions is never to create a swirl-free finish but to make the paint shiny and glossy fast. There's no profit in buffing out auction cars, it's all done to make the car presentable and sell.
Enthusiasts and Pro Detailers on the other hand learn to exploit M80 for all it's benefits and features.
While 205 and 105 is stealing the thunder I still use M80 it leaves the surface looking awesome it is easy to use and it is priced much better than the newer ones.
As long as Meguiars makes 80 I will continue to use it.
Originally posted by ShinyChevy View PostHey Michael, are the polishing oils in #80 the same/similar/different than the oils in Show car glaze or Machine glaze?
Originally posted by ShinyChevy View PostIs there an advantage in using either of them after #80?
You could apply a pure polish like #3, #5, #7, #81 or Deep Crystal Polish if you want to because you love your car, but if the M80 is finishing out well you probably wouldn't see a visual difference between the M80 results and the pure polish results.
Originally posted by Superior Shine View PostI love M80 on single stage.
It's probably the best first step product for restoring original and/or antique automotive paints if the goal is to revive and restore their original beauty.
Once a single stage paint is restored then M80 or M09 or any of the pure polishes work great for a maintenance polish to maintain the full richness of color and clarity of the finish. Of course, unless the car is in a Museum, follow your polishing step with an application of wax or a paint sealant of your choice.
#80 has a lot of oils. #7 is all oils.
So, on some paints, you wont see a big difference. On some, like black single stage, you can still see an improvement.
Originally posted by Michael Stoops View PostNot only does M80 make for a great paint cleaner, it has those wonderful polishing oils that will add that deep, wet gloss to darker colors and certainly won't hurt on a lighter colored vehicle.
Good stuff I agree!
Your plan sounds good. I am a huge fan of M80. I have some single stage paint that I hope to try it on this weekend if I have time. The pic below is what I was able to get with M80 and my G100. It is a lighter color that Chevy calls Light Silver Green Metallic.
Originally posted by ColonelCash View PostFrom what I have seen, M80 is fantastic on single stage paint. It was one of the first products I used when I got my G100. M80 and M83 are very good at removing defects, especially without having to use strong compounds like M105 and M95. A lot of times on MOL, M105 is the default answer...I'm guilty of it myself. Still, M80/M83 is a very effective combo for many cars and something I'm trying to use more often. Plus, it's cheaper than the newer stuff
Not only does M80 make for a great paint cleaner, it has those wonderful polishing oils that will add that deep, wet gloss to darker colors and certainly won't hurt on a lighter colored vehicle. For just light duty paint cleaning you can get great results with running as slowly as speed 3 and light to moderate pressure, or all the way up to 5 and moderate to heavy pressure to remove an awful lot of defects if need be. As an added benefit it has a pretty long buffing cycle to boot. Good stuff.
Good choice. I think M80 is also less expensive than M205, especially if all you want to do is clean the paint. I have used M80 for that purpose also. Works great!
