carbon fiber hood
  • carbon fiber hood
    hi every one i have a carbon fiber hood and i can see oxidation on it
    and i use turttle wax for oxidation and it came off it looks new but in hour or two some oxidation is coming back on the hood. can i use something else??
    thank you
    Re: carbon fiber hood
    Any chance of a pic?
      thank you
      This car came to me in pretty good shape already, but the customer wanted it perfect! I switched up my normal routine of SIP/White, which Ive always had great success with on this particular type of car and I went with M105/Yellow Megs Polishing Pad using the KB method. This process was much quicker and easier on my body since
      This is from one a the MOL greats, Maybe you can find some help here
        ill get some pic later
          http://meguiarsonline.com/forums/sho...t=carbon+fiber
          You were close in your link, instead, locate the "Popular Tags" box in the right hand column of the forum homepage and then find the word or tag carbon fiber and if you click on it you'll get these threads that all talk about fixing carbon fiber components.
          http://meguiarsonline.com/forums/tags.php?tag=Carbon+Fiber
          Carbon fiber is either clear coated, (More expensive components), or it's straight resin and if it's straight resin then it will oxidize and what you want to do is to remove the oxidation and use something with our polishing oils to penetrated into the resin and maintain it's clarity. After that you would wax it or apply a paint sealant.
          A great combo for a lightly oxidized carbon fiber surface is to use M80 Speed Glaze and follow this with a couple of coats of wax.
          If it's white and chalky looking then use Ultimate Compound, followed by some kind of Meguiar's polish and then a wax.
          Note that after you fix the problem you have to actively maintain the finish because nothing lasts forever and straight resin tends to oxidize easily.
          Be sure to click the link above and read through the threads and look at the pictures...
            hi mike what kind of polish and wax will i use after the ultimate compound and M80 speed glaze??
            thanks
              thanks
              The M80 Speed Glaze is the polish, so you would
              UC
              M80
              Seal the paint
              As for which wax or paint sealant to use I'll leave that up to you, NXT Tech Wax liquid is a good choice.
                hi mike how do i use all the pruduct u told me wich one goes first and do i have to wait to put the next one and do i have to use a buffer??
                thanks mike
