Using SwirlX with a G100
  • Using SwirlX with a G100
    What would be the suggested pad to use when using SwirlX with a G100.
    Thank You
    Opice1
    Re: Using SwirlX with a G100
    Thank You
    Opice1
    A Yellow W-8006 should do the trick for you.
      I concour, I used the yellow 8006 pad and it worked fine!
        What speed do you guys use?
        SFORealtor.com
          5.0 Speed Setting.
          Read through this,
          How To use: G110 - G220 - G100 - PC/Porter Cable - UDM
          If you're moving up to machine polishing, be sure to read the below thread before starting...
          Tips & Techniques for using the G110, G100, G220 and the PC Dual Action Polisher
          (These are all similar tools)
          And this,
            Everyone,
            Thanks for the information.
            Mike, I will read those articles.
            Thanks Again
            opice1
