Which Product for SwirlRemove with Pics
  • #16
    Re: Which Product for SwirlRemove with Pics
    M205 is a finishing polish so probably not a good match with a cutting pad. It is designed to finesse the finish, remove holograms and fine swirl marks while imparting a high degree of clarity to the finish. A cutting pad is going to run counter to this philosophy.
    You don't need to wash the pads first, but you may want to prime them with a quick, light spray of M34 Final Inspection first, especially the cutting pad. This will provide a bit more lubrication when the pad contacts the paint for the very first time.
    • #17
      Ok, I will try to get the polishing 2.0 pad
      And it's ok if I prime the pad with Quick Detail? because I don't have other product, and also I should to it before using the pad or while I'm using it?
      thanks!
      • #18
        You can substitute Quik Detailer if that's all you have. Priming only needs to be done with the first pass of the pad, it is not necessary to repeatedly spritz the pad during the buffing process. If you switch to a fresh pad part way through the buffing process, however, then a quick priming of that new pad would be called for.
