Rookie Bonded Contaminent Question
  • Rookie Bonded Contaminent Question
    I know there are two types of bonded contaminents: the above surface and below surface. I also know you use a clay bar on the above surface and a cleaner/polish for the below surface. I have always heard you need to clay it first beford you tackle the contaminents below the surface. My question is if you plan on using the cleaner/polish wouldn't it knock both of them out at one time and remove all the contaminents?
    Re: Rookie Bonded Contaminent Question
    No you wash a car to get rid of above surface contaminants.
    You Clay to remove the bonded contaminants.
      To clear things up a little bit.
      You clay to remove above surface contaminants and you use a Paint Cleaner or Cleaner Polish to remove below surface defects
      And you wash to remove loose contaminants that have not yet bonded to the paint
        The foam pad will actualy skip over them if they are well bonded. And if they are not well bonded, they can come off and drag across your paint.
          No, you need to:
          1. Wash
          2. CLAY
          3. Then Cleaner Polish
          Clay will actually pick up and remove bonded objects. You need to do both
          Matt
