Fine Scratches after Deep Crystal Paint Cleaner
  • Fine Scratches after Deep Crystal Paint Cleaner
    Quick question for anyone if they can help.
    I had a couple of small scratches near my door handles and I used the Meguiars Paint clearner product which took them off. Tonight when I got home, looking at the door handle area, I noticed now there are small fine scratches now. Would u recommend using this scratch x for fine scratches or should I try again the paint cleaner but not as hard or rough ?
    THanks
    Re: ScratchX 2.0
    THanks
    What kind of "paint cleaner" did you use?
    Either way, ScratchX 2.0 would be a great choice for cleaning that area up.
    Also, you may want to consider what it is that is creating the scratches, and see what changes in behavior can be made to at least minimize future damage
      Re: ScratchX 2.0
      It was the Meguiars Deep Crystal Paint Cleaner. I applied it via a brand new terry cloth. I was thinking about switching to an applicator pad and trying again with " loving touch "
        Re: Fine Scratches after Deep Crystal Paint Cleaner
        First... we moved your questions into their own thread. Sometimes it's more beneficial to you to start your own thread when you have a questions about a detailing project or problem.
        I had a couple of small scratches near my door handles and I used the Meguiar's Paint cleaner product which took them off. Tonight when I got home, looking at the door handle area, I noticed now there are small fine scratches now. Would u recommend using this scratch x for fine scratches or should I try again the paint cleaner but not as hard or rough ?
        THanks
        It was the Meguiar's Deep Crystal Paint Cleaner. I applied it via a brand new terry cloth. I was thinking about switching to an applicator pad and trying again with " loving touch "
        Switch over to a clean, soft foam applicator pad and try re-applying the Deep Crystal Paint Cleaner. If that doesn't work then try a clean, soft foam applicator pad with ScratchX, either the old version or the new version.
        Clear coat paints are scratch sensitive and often times terry cloth by itself with some pressure will instill scratches.
