Deep Crystal Steps
  • Deep Crystal Steps
    I need to know how aggressive/abrasive the Deep Crystal PAINT CLEANER is. I ordered it by accident instead of the Pure Polish a While back. I explained the cheap paint job (single layer w/clear mix,etc). I ordered the Step 2 Pure Polish, which is what I actually wanted tonight. I can't imagine Step 1 being very aggressive at all, but thanks.
    On this Cheap Paint, Hopefully I will:
    -step 1
    -step 2
    -nxt 2.0
    Matt
    Re: Deep Crystal Steps
    Sorry I can not help you there.
      That's ok, I am sure i will be alright. I just need to check so I don't go through the paint.
      Matt
        DC1 is a very mild product.
        If you have used A12 Cleaner Wax before I believe that DC1 is a little bit more aggressive than A12.
        How did you apply DC1? Did you just apply and remove or did you work the product against the paint?
          Matt
            It is very mild, but it's also how you apply it, put it on a piece of sandpaper and you know what will happen, by hand with a yellow applicator won't do much
            How did you apply it and/or going to apply it?
            It's a great product.
              The product itself (looks at Aaron...haha) is the mildest paint cleaner available from Meguiar's.
                Most likely by hand with the Yellow Meg's Applicators. I will be gentle
                But I would really like to use my G110, but I'm not sure if Step 1&2 are made for that?
                Matt
                  I just looked at my bottles, it suggests to use the yellow applicator, but I know I used DC1 with my G100, so I don't think you'll do any harm using your G110 with DC1. DC2 is a pure polish, no cleaner, just a gloss coat, you can use your G110, do one section at a time unless you have a second body to wipe off the polish as you go with the G110 . I put polish on by hand (DC2 or M07) like a wax and a thin coat then wipe off.
                  But! always do a test section
                    Yeah, you should be able to use them on the G110.
                      Prior to finding the pro line I used the Deep Crystal line with my PC and had very good results... So, yes you can use Deep Crystal #1, #2 and even #3 via PC, they will give great results. The DC line are a very good 'entry level' products, inexpensive, easy to find, easy to use and best of all they work!
                      Brandon
                      2007 Black Chevy Avalanche
                      My Albums: Avalanche
