Quick Question on ColorX and polish
  • Quick Question on ColorX and polish
    Hey guys,
    Just wanted to first say thanks for a great website. I have been searching for 2 weeks now on what to do for my car. Unfortunately, with all the info out there I think I'm overkilling.
    I'm basically removing some swirls and restoring the luster back to my paint. The paint is dark blue on a 2005 Altima. This is what I'm using and just want to know if its too much:
    1. Clay bar (Meguiars clay kit)
    2. Scratch X 2.0 (cleaner Polish)
    3. ColorX (Pure polish?)
    4. NXT 2.0 Generation Wax
    Does this sound okay? And is ColorX a pure polish?
    Thanks!!
    Re: Quick Question on ColorX and polish
    If you want to do a multi-step process then out of the products you listed you would,
    Wash
    Clay
    ScratchX
    NXT Tech Wax
    ScratchX is a dedicated paint cleaner
    ColorX is a cleaner/wax, that's like a paint cleaner, polish and wax all-in-one
    NXT is a finishing wax
    If you use ScratchX you don't need to use ColorX, you can go right to NXT Tech Wax
    The cleaning step is the most important step and it is this step that will for the most part determine the end results.
    Hang on, I typed up some information on this yesterday...
      Color X is a cleaner sealant.It is a perfect prep for NXT2. Use the Scratch X only were nessessary. The combo of ColorX and NXT2 should make your car look great.
        Check out my comments on page 2 of this thread...
        I have had an associate tell me, that after clay barring his car, He then Scratch-Xed the entire car... Then applied NXT 2.0. I saw the car before he did it... it was rough (2006 TopBanana Daytona). I saw it a couple days after he was done... looked great. I just clayed my car for the first time... Wondering if using Scratch-X
          i've used the colorx and nxt combo many of times with good results. the paint didn't really need to be polished out with a dedicated paint cleaner, so using the colorx instead worked excellent in my situation and topping it with nxt made it even better...
            Just to chime in, other's have recommended ColorX then NXT instead of ScratchX and it's true this is a popular and effective combination. Basically you're using the ColorX as your paint cleaner and as a bonus it's also polishing and laying down some wax protection.
            Generally speaking, you'll get better cleaning results when you use a product that's dedicated just for that task, not cleaning, polishing and waxing although if a finish isn't in too bad a condition to start with then there wouldn't be much visible difference to go with either product before NXT.
            The benefit to using ColorX is that if you find you have to stop your detailing session after the ColorX application your paint will be protected. ScratchX doesn't leave any protection behind so it must be followed up with a wax.
            Two approaches, both with different benefits.
            Your choice.
              Mike,apparently you and me posted at the same time. Im sorry if I stepped on your toes. My idea about ColorX followed by NXT2 is just my opinoum.You are the expert on Meguiars products, so your advise should be followed. From what Im been reading I think that the new Swirl X will be the perfect prep for NXT2. I cant wait to get a hold of some.
                Originally posted by Larry A View Post
                Mike,apparently you and me posted at the same time. I'm sorry if I stepped on your toes.
                No problemo...
                We both posted great approaches to get great results. The ColorX/NXT combo is a time-proven, very effective system approach with it's own benefits.
