quick question
  • quick question
    what do you guys recommend to use to get sap off of a car?
    nothing major just little specks of sap on my car
    Re: quick question
    Meguiar's Smooth Clay Kit. I have to use this about once a month to remove the sap that bonds to my paint from parking at work.
    George Carlin
      Re: quick question
      thanks man that helps alot. lol my clay is too old somewhat sticky. is it suppost to be that way after time? and when i use it on the car it leaves white marks and is really hard to get off
        Re: quick question
        It seems that you're not using sufficient amount of lubricant while claying.
          Re: quick question
          well how much are you suppost to use?!?!
          could it be im applying too much pressure? because i put ALOT of lubricant on there but i still get white marks
            Re: quick question
            Use sufficient enough to keep the surface always lubricated. You don't need to apply pressure to the clay, just glide it back and forward continuosly
              Re: quick question
              I agree, definitely try claying.
              '05 Arctic Blue Pearl Acura TSX
              '03 Silver Lexus RX 300
                Re: quick question
                Light pressure, a good amount of lube, Try quik detailer or last touch diluted 1:1 and you should be okay.
                  Re: quick question
                  It could be the clay is bad, have you ever used it with something else besides a quality mist and wipe product?
                  How fast are you moving your hand? If you move your hand slowly the clay has time to smudge at the end of your throw. Claying should be a fairly fast hand movement just to avoid smudging.
                  How to use detailing clay video
                  For the future on any forum...
                  How to write a great subject for your message!
