I need some info about carbon fiber and what porducts I should use on them.
  • I need some info about carbon fiber and what porducts I should use on them.
    My assistant manager has a gorgeous integra, just got fresh paint. and he has a carbon fiber hood with oxidation. I think it is a gel coat because it is a whitesh color oxidation but it does not look like clear coat failure. Is it fine to use M80 or 83 on a gel coat finish? I have never worked on a gel coat finish before is it a lot a like a clear coat?
    Alex
    1972 Dodge Dart Swinger360
    1998 SVT Cobra 1 of 551
    1969 Ford Mustang Fastback
    Re: I need some info about carbon fiber and what porducts I should use on them.
    i think theres marine line products taht are specially designed for gel coats.....
      Do some searching as I know I have seen this topic many times. Check back if you don't find what you're looking for and I'll take a look myself.
        To know for sure, get the brand and contact them to see exactly what type of finish is on it.
          Thanks guys, I did some looking around on the forums and I think m80 will do the trick to remove the oxidization. I am going to call the manufacturer if my boss remembers the company name. Sorry for the kinda pointless post.
          Alex
          Alex
            Usually, if it is a reputable brand, there is some sort of tag or plaque underneath the hood.
              If it is a gel-coat, shouldn't the Marine Line of products work on it?
              Just a thought
                See post 2
                  Just for clarification, you can use the Professional Line products on gel coats.
                  I've used both diminishing abrasives and non-diminishing abrasives on these paints without a problem.
                  Chris
                  Dasher Detailing Services
                    Look for the words Carbon Fiber in the Popular Tags Box.
                    Also, M80 works great for restoring oxidized carbon fiber components in most caes, if it's really oxidized badly, then you may need to use an aggressive compound with a wool pad on rotary buffer or it could be past the point of no return.
                    The Popular Tags Box
                    On the forum homepage in the right hand column there is a box titled,
                    Popular Tags - (This is a link to the actual tags in the box)
                    Sometimes you can find information on a hot or popular topic by looking for keywords in this box.
                    Comes in real handy...
                      Thanks you guys. I just did a search and I did find a thread similar to mine. The hood was turning white and hazy which is the same symptoms as the one I would be working on and M80 was mentioned in the thread so I am going to give 80 a try. I will do a test spot and see how it turns out. The other day my work I took a different brand of polish and did one spot and it looked much better but the oxidation is still there so I am thinking if I take 80 it might be able to bring it back. I will see about maybe doing the car today if he is at my work. His new paint job has swirls in it already. I will take pics.
                      Alex
