Since winter is just around the corner and in some parts of the country it seems like it's already here, I thought I would put this out there. As we all know the surface temperature needs to be between 60 and 80 degrees Fahrenheit for best results when using Meguiars products. So, with that said how do you guys keep your garage at the appropriate temperature for detailing? Please list brand names, models etc of any heaters you're using.
Heater question...
Re: Heater question...
Originally posted by ColonelCash View PostRadient heat panels on the ceiling of the garage.Originally posted by hondamtrco4life View PostReally? Okay, nice! How much does something like that run?
Since I have a detached garage and would require either a gas line or a larger electric line to have the kind of heat I would really like, I took the cheap way out.
I have a portable torpedo style 90,000 BTU Reddy Heater kerosene heater. Noisy, a little smelly, but not too bad on either count. It will raise the temperature in my uninsulated 24' x 32' garage 20 to 30 degrees in about 15 minutes. Had the same heater for almost 30 years.
They probably are close to $300 today. A similar heater is avaiable for use with propane.
It looks a lot like this one, but not exactly the same.
Charles
The Rainmaker
Hey Andrew,
I picked up this heater at Northern Tool for like $400. Works like a champ!
Rasky
I have a natural gas ceiling mounted one and I love it. Works perfect for me. My garage is a bit bigger than a 2 stall, the heater is a 45,000 btu.
Mine is a different brand but basically the same as this one... Mr. Heater Natural Gas Garage Heater — 45,000 BTU
Any questions just let me know!
Edit: Rasky, great minds think alike! lolScott
Originally posted by BlueZero View PostI have a natural gas ceiling mounted one and I love it. Works perfect for me. My garage is a bit bigger than a 2 stall, the heater is a 45,000 btu.
I also have a HOT DOG brand one in my other garage that runs on natural gas. Since my shop is in the detatched garage it runs on propane. I have a 100lb tank out back.
I have a natural sun heater in my area. You open the garage and let the 70 degree weather pour in. It gets a little expensive, but it works.
Sorry, I had to do it...Attack life, it's going to kill you anyway.
Originally posted by Ryan L. View PostI have a natural sun heater in my area. You open the garage and let the 70 degree weather pour in. It gets a little expensive, but it works.
The weather said it could snow here this weekend. Looks like a low of 28 F on Monday night.Scott
Northern Tool has a couple nice electric heaters, glad Rasky mentioned the name. There is one on their site for $109 with really good reviews. I might have to get one for the new garage. My neighbors garage did have radiant panels on the garage ceiling. This was to keep the temp constant in the garage, as well as the living room above it. Very nice, although expensive I'm sure.NOTE: Post count does not reflect actual detailing knowledge.
Originally posted by ColonelCash View PostNorthern Tool has a couple nice electric heaters, glad Rasky mentioned the name. There is one on their site for $109 with really good reviews. I might have to get one for the new garage. My neighbors garage did have radiant panels on the garage ceiling. This was to keep the temp constant in the garage, as well as the living room above it. Very nice, although expensive I'm sure.
I used one of those electric heaters in my one stall apartment garage. It was fully insulated. After a couple of hours running it, it was 5 degs warmer. I would say don't waste your time.
Check out something like this then... Mr. Heater Portable Propane Forced Air Heater It will run right off of a 25lb tank like a gas grill uses. My parents have one and we've heated up their uninsulated 2 stall garage pretty good with it.Scott
