Last Night Detailing Question...Weird?
  • Last Night Detailing Question...Weird?
    So, yesterday I was detailing my truck. It was around 6pm, so it was getting dark and colder, around 44-46 degrees. I was using 80 then followed up by NXT 2.0. When I was using M80, it didn't take out as many swirls as it used to, so after using 80 with the DA, I wiped it off and got a smearing effect on the paint, so I just kept wiping until it was gone (or as gone as I could get it). So, I thought it was the 80. I put the wax on, and it went on fine, then when I started to take the wax off, it was doing the same thing...smearing. It took me about 45min to take the wax off of the truck using the DA, which usually takes about 10. So why did this happen? Was it too cold? Or was I doing something wrong?
    Process from the Detail:
    Clay- Blue
    80
    2.0
    G110
    2004 Black FX4
    Re: Last Night Detailing Question...Weird?
    Might have been getting too damp to work well?
      I live in Wisconsin and had a similar problem. I think that it is too cold and damp to be working. Tell me how it was today, or if you could get the wax of with out lines. You should probably try another coat and let it bond for an hour.
        What temperature ranges are best for applying cleaners, polishes, and waxes
        When we talk about surface temperatures, we need to consider three factors:
        • Surface Temperature
        • Ambient Temperature
        • Relative Humidity
        • Surface Temperature (Actual surface temperature of the vehicle)
        The best surface temperature range for applying cleaners, polishes, and protectants is approximately 60 degrees to 80 degrees Fahrenheit. More importantly, the surface does not feel warm or hot to the touch.
        Basically, when you're working within this temperature range, it's not too cold, and it's not too warm to realize exceptional results from just about any Meguiar's product.
        Meguiar's products will work easily within a much broader temperature range, such as, 50 degrees to 90 degrees Fahrenheit, but guaranteed best results will be achieved in the 60 degrees to 80 degrees range.
        Ambient Temperature (Outside temperature)
        Ambient temperature is the room temperature or the temperature of the surrounding environment. It's easily possible to have between 10 to 50 degrees difference in ambient temperature compared to surface temperature. This can make the difference between a product that's easy to work with, or hard to work with. Keep in mind, the hotter the ambient temperature, the quicker products will dry.
        Humidity (Moisture in the air)
        Simply put, humidity is moisture in the air. Technically there is Relative Humidity and Absolute Humidity, but as it relates to:
        • Applying
        • Working with
        • Curing, drying, hazing
        • Wipe-off or removal of car care products.
        The simple explanation of moisture in the air, or more specifically, the amount of moisture in the air is the major factor, which will affect how easily or potentially difficult a product will be to work with, or a procedure will be to perform.
        Low humidity, in warm to hot temperatures, will act to cause liquids to evaporate and dry more quickly. This can make a product difficult to work with or decrease the amount of time the product remains easily workable on the surface.
        High humidity in cold temperatures can make products hard to work because it can dramatically increase the amount of time necessary for the product to cure, dry or haze (depending on which product you're using).
        Low humidity in low temperatures tends not to be a factor in working with, cure times, and when applying and in the removal of cleaners, polishes, and protectants (Low temperatures are a factor, but not low humidity in low temperatures).
        High humidity in high temperatures tends not to be a factor in working with, cure times, and when applying and in the removal of cleaners, polishes, and protectants (High temperatures are a factor, but not high humidity in high temperatures)
        Extreme temperatures, both cold and hot will make any product more difficult to work with.
        Direct sunlight
        Direct sunlight will dramatically increase the surface temperature compared to ambient temperatures and make cleaners, polishes and protectants extremely more difficult to apply, work and remove.
        Air current/Wind
        Air current/air flow, or windy conditions will act to increase the evaporation speed and potentially making some products more difficult to apply, work, or remove. In some cases this can be a bonus, helping a wax to cure/dry more quickly.
        Summary
        The best conditions for using cleaners, polishes and protectants on automotive paints would be in a cool place, out of direct sunlight, in a surface temperature range between 60 degrees and 80 degrees Fahrenheit, with comfortable to low humidity, with a light breeze to create the perfect conditions for detailing your car's finish.
        Common sense and a good rule-of-thumb is to avoid applying any product if the surface is too warm to touch with the palm of your hand comfortably.
        50 degrees Fahrenheit = 10.0 degrees Celsius
        90 degrees Fahrenheit = 32.2 degrees Celsius
          About that time of year to start working more in the sun really if you are in the cold areas.
            I've experienced the same things not necessarily with products, but even with just wiping your car down after a wash. With water I just use a little QD to help convince the water that it wants to be absored. Not sure what would be best with certain products but I imagine the NXT 2.0 would just need longer to set.
            "Difficult takes a day, impossible takes a week." Jay-Z
