cleaning aluminum wheels
  • cleaning aluminum wheels
    Is this the correct process for cleaning a polished aluminum wheel? rinse, clean with an alum. cleaner, alum. polish, then wax?
    What if it's clearcoated?
    sorry if it's a noob question
    2004 Mustang GT - Sonic Blue
    Re: cleaning aluminum wheels
    Well, its kind of a noob question.. but its also compliated. There are many kinds of aluminum, different coatings, uncoated, polsihed, etc, do you know what you will be working on?
      For polished aluminum, your process will work fine. I like to wash with soap and water though. The milder the wash, the longer the shine will last. I haven't waxed mine either, but I am sure you could.
      If it has a C/C, treat it like paint.
        so use the deep crystal system with a C/C?
        Im not sure if the wheels are clearcoated or not
          Yes.
          If your towel turns black when you polish it then its not C/C.
            Do a search using the word
            Blackish
            Here you go...
            Can somebody tell me what is the best way to clean aluminum wheel's?? There off a 97-01 Jeep Grand Cherokee Limited. Thank's
            And...
            Quote:
            Originally Posted by MrWaxer
            I assume they are. This may sound crazy, but how can you tell!!
            Rub a little paint cleaner that's whitish in color, like ScratchX or Deep Crystal Paint Cleaner, using a clean white cloth to a clean rim for a few seconds and then turn the cloth over and inspect. If you see a dark grayish or blackish color then you have uncoated aluminum wheels. If the cloth mostly remains white then you have clear coated rims or anodized rims.
              thanks mike!
