what do you guys all use,would it be ok,or last,by using hotshine aresol,or tire foam?and would it hurt anything by doing the same on plastic parts under the hood and intake manifold?thanks
wheel well dressing
Re: wheel well dressing
It would be ok for wheelweels, though ASD would likely be more cost effective.
I dunno about under the hood. I have used ASD on occaision under there with no problems, but some people seem to be against it because of the heat.2017 Subaru WRX Premium - WR Blue
Originally posted by spence82 View Postone reason i was asking is i have some black magic tire foam and do not really care much for it,its just sitting around collecting dust.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Originally posted by Playr View PostUnder the hood, nothing beats . . . should I say it?
CD-2 engine detailer (if you can find it).
That said, I don't care for the application, seems I have to saturate the entire engine bay to ensure all surfaces are covered, it seemed to use a lot of product and the smell will get you during application!Brandon
On the plastic fender well inner linings, I clean them with a brush and soap, then once dry, I simply apply silicon-based tire dressing to them. It blackens them really well, and makes them a breeze to keep clean.2006 Chopped and Dropped Dodge Grand Caravan SXT
Hi Tim,
Sorry, ""nothing beats" is a bit confrontational.
Isn't hyper dressing water based? Not that one will get a bunch of water in the engine well, otherwise you'll have bigger problems.
That said, I have not tried hyper dressing. But the product I mentioned is that good that once you use it, it's hard to deviate.
Rather than continue to trounce all over spence's thread as soon as I detail my engine (I'll try tomorrow) I'll post my own report (w/ pix and all).
Happy Easter.I'm crafty, but not good at crafts.
To put things back on topic...
For wheel wells, I use Meguiar's Hyper Dressing at a 3:1 dilution. As I have mentioned over the years, it does not attract dust as much as other dressings. It applies easily and spreads out evenly.
My other product which I still have a special stock of is the discontinued Meguiar's Engine Kote.
