First Question posted please read and help
  • First Question posted please read and help
    Hey guys,
    I have a question about some of the steps I should take. I am getting ready to detail my truck and I just want to check on a few things. I am going to do many steps on my truck some will probably include:
    Using 84 (couple passes and then 85 if needed)
    then I will move onto 80, 82, or 83 depending on what the pain looks like will determine which one I use. I know always start with the lest aggressive and work up higher if needed.
    My question is after I use 80,82, or 83 is there a need for me, would it be beneficial for me to use 5 or 7 after using 80,82, or 83. I know the 80, 82 and 83 are a cleaner/polish I was just wondering if it is best to go back with a pure polish that does not have any cleaning agents in it.
    My next question is:
    Is 21 considered a wax. I know it says it is a sealant. Do you have to put on a wax after you put on the 21. I was thinking of putting on 21 and then it up with 26.
    Any help or ideas would be great.
    Thanks in advance
    Re: First Question posted please read and help
    Are you workling by hand, or PC?
    If so, #83 with a 8006 pad is considered the most aggressive one can go. Some of the pros can do a bit more, but yo\u are kind of going out on your own.
    As far as the pure polish, if you have a dark color, you might see some difference in the look, but #80/82 have enough oils in them to take care of the paint.
    #21 is a synthetic product... after that, call it what you like. Meguiars tends to use the terms sealant and wax interchangeably. There is no need to follow up #21 with another product, 2 coats of #21 would be fine. But if you want to use #26, you can do that as well. Up to you.
      Thanks for the info. I will be working with a pc and I also have a rotary.
      Kris
        Ok. The rotary would be for the 84, 85 then.
          That is correct. I was also wondering can I put the nxt 2.0 over the #21 if I decide to double up. I am assuming everything in the meguiars line is compatable.
          Kris
            Kris
            Hi Kris,
            Yes you can place NXT 2.0 over #21 if you wish; and yes, Meguiar's products are all compatible with one another.
            Please post some pics when done!
              Thanks for the help Tim. I will post pictures when I get done. I am going to take before and after pictures. I will probably not be able to get to the truck util next week.
              kris
