Detailing ?'s for my '02 Honda
  • Detailing ?'s for my '02 Honda
    I've been detailing my vehicles as far back as I can remember but only by hand. I recently ordered the G100 DA polisher & plan to use it on my wife's '02 Accord. Unfortunately her car has taken a beating from highway construction debris and I need to get it back into shape so here's my plan:
    > NXT wash
    > Smooth Surface Clay application
    > #2 Fine-Cut Cleaner application
    > #5 New Car Glaze polish application
    > Finish off with NXT Tech 2.0 application
    So does this sound good?
    Thanks in advance,
    Rob
    '06 SeaDoo RXP - Stg I+
    '06 SeaDoo GTI - Wife
    '07 Titan - Lightly Modified
    '93 Stroker Mustang GT - Untuned
    Re: Detailing ?'s for my '02 Honda
    Looks Good!
    Just to add, #83 is always nice to have in case you need to correct more serious problems.
    What pads are you using?
    Chris
    Dasher Detailing Services
      Naturaly yo uwont be able to fix chips by machine... read these over:
      Step 1 Wash
      Step 2 Clean
      Step 3 Polish
      Step 4 Protect
      Step 5 Maintain
      Suggested Products for Taking Care of a New Car
      How To Remove Swirls By Hand
      Each one, teach one... Ferrari Fiorano 355 F1 Spider
        Thanks Chris.
        Actually I forgot to ask abt the pads . I was planning on using the W8006 to polish & the 9006 for the NXT application but I'm not sure what to use for the Fine-Cut Cleaner; what do you rec?
        Rob
          Thanks for the links; I'll be sure to read up
          Rob
            I would say depending on what country you are in, #2 and #5 probably arent what you want.
            Read the above links to see about #80 and #83.
              Even though #2 is an older style cleaner, it still works fine. I'm guessing you've already found it, though. ...sounds like O'reilly...
              I really like the cleaner / polishes - #80, 82, and 83. However, these are a little difficult to obtain in some places.
              The pad used in conjunction with a cleaner depends on the cleaner and what you are trying to correct. The lighter cleaners (#80, 82, 9) can be used with a finishing pad or a polishing pad. Cleaners like #83 and #2 should be used with a polishing pad.
              Pure polishes, like #3, 5, and 7, should only be used with a finishing pad. They don't have any cleaners, so it's useless to use a polishing pad.
              How bad are the defects?
              Chris
                LOL! I'm in the good ole' USA.
                Actually I was reading one of the links you posted. Should I go with #80 & #83?
                Rob
                  As Chris said, #2 would work, but the newer cleaner/polishes would likely be better for you.
                  Now #5 is a pure polish meant for high humidity environments like the tropics, so even if you want to use a pure polish after the cleaner/polish, #7 would be the best, with #81 close behind.
                    If given the choice of #80 or #2, I would go with #80. #80 is very easy to work with and leaves a nice finish. I should mention that #2 fits in between #80 and #83 in terms of cleaning ability.
                    #83 can remove deeper swirls and scratches than #80.
                    Chris
                      Chris,
                      The defects are not that bad. A few scratches here & there from the wife & kids & then chips from the highway. The car is still shiny and I have always taken good care of it, like all of my vehicles. Wish the wife was as Anal Retentive as me .
                      I have a dealer that carries a pretty good assortment of Meguiar's products so I'm lucky.
                      Thanks for your input,
                      Rob
                        Thanks for all the help guys. I went ahead and picked up a bottle of #80 & #83. Hopefully I'll have nice weather this weekend so I can test them out to see which one works best.
                        Results coming soon...
                        Rob
                          I polished my wifes '02 Firepepper Red accord last summer.
                          - Washed
                          - Clayed
                          - #80
                          - #7
                          - NXT wax
                          #80 took about 90% of the detects out. On some of the larger/deeper ones, I spent more time than the rest of the car and made them look pretty good.
                          I haven't polished a lot of vehicles, but I'm going to consider the paint a medium hardness. My Subaru paint seemed softer and I couldn't touch the paint on an Audi A3 with #80. It was incredibly hard.
                          Polishing really seemed to darken the color of the paint. It went from pinky to maroon. #7 added a bit more darkness.
                          Have Fun!
                          It's only weird because it's not normal
                          www.project-one.us
                            I waited 3 weeks for a perfect weekend to detail my Accord & yesterday was it. Here's what I did:
                            Step 1 - Clayed entire vehicle
                            Step 2 - Applied #83 using G100 DA polisher with W8006 pad on setting #5
                            Step 3 - Applied #80 using G100 DA polisher with W8006 pad on setting #5
                            Step 4 - Applied NXT Tech Wax 2.0 using Meguiar's cordless polisher &
                            by hand for the tight areas with W9006 pad
                            Overall I'm pleased with the results but there were some scratches & paint etchings I couldn't get out. What's you're advice on removing these?
                            Thanks in advance,
                            Rob
                            Rob
                              Where are the pictures?
                              www.project-one.us
