Using Meguiars Products step by step
  • Using Meguiars Products step by step
    I would like to begin using Meguiar products but was just curious on what products are applied in order(in general).
    So please if anyone out there c an help me out greatly appreciated
    Re: Using Meguiars Products step by step
    Well, here are the basics for working by hand:
    Step 1 Wash
    Step 2 Clean
    Step 3 Polish
    Step 4 Protect
    Step 5 Maintain
    Suggested Products for Taking Care of a New Car
    How To Remove Swirls By Hand
    So give those a read over. Any info, pics, etc you can share about your car, goals for the car, time available, etc can all help with product choice, both for your research and any recommendations we make.
    Dont get too freaked out by the large number of products. There are a lot of products to cover every situation, rather than only one product that must fit every situation. So you might need a little time to get familiar with everything but no big deal.
    Just read the basics there and ask away
      I start on Saturday afternoon. My very first time I have ever waxed a car before. I began by washing it and hand dried car. I clayed it with the detail spray and was amazed at all the junk that the clay removed. I used both bars in my kit to complete job. I washed it good a second time and again hand dried. I then used the paint cleaner and followed it with a coat of polish. I only used one coat of polish, I was considering on two but stopped after the first. I then switched to the liquid NXT and have done two coats so far. I am pleased with the results. The paint I thought was beautiful before I started, but what a huge difference. I believe I am going to do one more coat tomorrow and wrap it up with three coats. My question is there anything else I can do after three coats of wax. I have the spray NXT wax and the Quick detail spay and was wondering if I should top the third coat with anything else. I am so happy with the results of Meguiars. I will post pictures once the sun returns. I have waxed my Shelby in my garage and had my son follow me with my wife's hairdryer. HA! HA!
        Thanks. I dont feel that worried now with the info i received from you guys. Thanks alot.
        Good night
          The spray wax can be used after future washings to bring back that fresh waxed look. Takes a little getting used to, but once you get the technique, it can go really fast. It isnt meant to be applied like a regular wax, just a skim coat.
          How to Get Great Results Using Meguiar's Spray Waxes
          the detailer can be used after washing if you wanted to get a fresh shine at least, and can even be used while doing your final wipe around drying. However it is also important for removing bird droppings, berry, etc, etc.. before they can stain or etch your paint.
            The steps that you mentioned above are those the same steps one can do with a DA? Or are the steps different?
              With the DA, things can get changed up a little. You still want to follow the same process, wash-clay-clean-polish-wax, but with different products, it will look a little different. Here are two links for the DA use....
              Basicaly, #80 Speed Glaze is your main go-to product, and it is a cleaner/polish, so it covers both steps in one, making a seperate step with a pure polish optional.
              Some of the same products could be used, but generaly speaking, the Consumer Line products are meant for hand use, and the Professional products are meant for machine use, and you will tend to get best results when using the products that way.
                Okay sounds good. I am a mobile detailer and would like to bring Meguiars in as my arsenal. I have seen and heard alot of good things about Meguiars. Where does the scratchX and things like that come into play?
                  ScratchX is a stonger paint cleaner to use by hand to remove mild swirls and scratches, as a couple of the links up in my first post show. Even as a molbile detailer working by machine, you would want some of that on hand to reach the places that a G-100 cant.
                    As usual, Murr is correct. I have a DA, #80, #83, and #82, but I still keep a tube of ScratchX around to hit small spots.
                    Lydia's Mobile Detailing
                    2007 Honda ST1300 - Silver
