#80, how often?
  • #80, how often?
    I just finished using #80 with my new PC and topping it with NXT. IT turned out great on my black truck. How often is it safe to use 80 . When would it be needed again. thanks.
    Re: #80, how often?
    It will be needed again when you deem the swirls or other defects are bad enough to warrant another polishing. As for how often you can do it......every six months and you should be OK, even with "spot" touchups in between if needed.
      Re: #80, how often?
      PLEASEEEE use the search function. this is like the millionth thread on this. haha not to be rude. just sayinnn. thank you!
      02 Ford F250 Super Duty
      International T444E 7.3L Diesel
      Not exactly stock...laundry list of mods.
      Straight Piped
      PHP FU chip
        Re: #80, how often?
        this is been discussed a number of times and in great lengths.
        however, having said that, if you maintain and wash the vechile properly you should be okay not to use it once a month, meaning you should NOT have to.
        if you are having to, then you need to stop the swirls are the source and not work so much to repair them.
        try this link.
        http://meguiarsonline.com/forums/sho...+frequency+use
        sometimes some people aren't familiar with the search tool and don't know exact words to type to get what they want.
        we're all here to help.
          Re: #80, how often?
          Thanks guys . Im not a big computer user but I,ll try the search box in the future. I'll do a search for #80 drying out because I had that problem also.
            Re: #80, how often?
            M80 does not have to dry.
            you apply it properly and then buff it off. work with a panel at a time. a small area so that it doesn't dry.
            take a read here mate.
            http://meguiarsonline.com/forums/showthread.php?t=12031
