Marine Wax
  • Marine Wax
    Can Marine Wax be used on Cars?
    example : Flagship and Marine Cleaner Wax?
    If yes .. will it last longer than other Meguiar car waxes?
    whats the benefit of Marine waxes on Cars
    OR its not recommended to use on Cars and Clear Coat
    Re: Marine Wax
    bump!!
      Re: Marine Wax
      Well isnt marine paint gel coat? I assume it is made for that and should be used on that. But I dunno lets see if mike rings in here.
      02 Ford F250 Super Duty
      International T444E 7.3L Diesel
      Not exactly stock...laundry list of mods.
      Straight Piped
      PHP FU chip
        Re: Marine Wax
        Mike commented on this when it came up a couple years ago. It's probably fine but not optimal.
        a friend of mine said he used boat wax on his car and it looks mint. is this safe to use? i would think it's meant for fiberglass only?
          Re: Marine Wax
          The marine Line is formulated for gel-coat/fiberglass and the Professional Line is formulated for single stage and clear coats. You will probably get the best results from the product that it is made for a certain application.
          The above is from my experience and research
            Re: Marine Wax
            Marine gel coats are much thicker and harder than automotive paints. This means that the cleaners are going to be more aggressive in order to be effective. So, we say do not use any marine products on cars.
            John Keeling
            Meguiar's Customer Care
            800.854.8073 x113
              Re: Marine Wax
              Meguiar's recommends using our Marine Line of products on marine surfaces and coatings and use our Automotive Line of product on automotive coatings and surfaces for optimal results.
              Our chemists formulate our products for specific surface materials and coatings as well as environmental conditions, so best results will be had when you match the correct product line for the vehicle or marine vessel you are working on.
