Clarify: Please explain "Paintable" Cleaner Polish
  • Clarify: Please explain "Paintable" Cleaner Polish
    I have some #83 Cleaner Polish I'm about to use for the 1st time. It says 'Paintable.' Can someone please clarify exactly what this means?
    I plan on using 83 on all my car except the hood, which I will repaint. Can I then use 83 on the hood to smooth it out, then continue sanding, priming and painting without having to strip the 83 off first? Not sure what this means.
    Thanks!
    Jamie
    Re: Clarify: Please explain "Paintable" Cleaner Polish
    I was able to find the answer to this. It means that the product is able to be stripped away prior to painting, with chemicals normally found in a paint shop.
      Actually I believe paintable means that it is a paint shop safe product, meaning it contains no chemicals or silicones that could contaminate the paint shop environment creating defects such as fisheyes when painting.
      Brian
        Mister B is correct
        In a nutshell...a product that is "paintable" means it is safe to use in a painting environment with out the risk of causing "fish eyes". There are certain chemicals that paint doesn't like to stick to. If those chemicals are in product, we deam them as "not paintable"...Some people refer to this as "does it contain silicone" or is it "silicone free"... and if it does contain silicone it is "not paintable"...
        Well, they are assuming that "silicone" is always not paintable...Not true....There are some silicones that are
        We chose the word "paintable" as a better way for the shops to be sure it can be used by them with no risk
        Keep in mind, once a car is painted then it is no longer an issue...
        Mike Pennington
        Meguiar's, Inc.
        800-854-8073
        mpennington@meguiars.com
          Mike thanks for clearing that up. Its something I have been meaning to ask, but have not had the opportunity to do. Thanks again.
