dust removal from car finish
  • dust removal from car finish
    My 1982 Buick Regal was picked up from paint shop yesterday, and I now have it in my garage.
    during transport, it now has a layer of dust on it. what would I use to remove the dust, without scratching. the paint is 28 hours old. could I use Quik Detailer to get the dust off? should I wash first?
    1982 regal limited "BLACKMAIL"( just your typical 550 hp v8 regal )
    1989 Chevy 1500 Suburban(new tow rig/daily driver)
    jeff wecker, abilene,kansas
    Re: dust removal from car finish
    Do not use Quik Detailer on fresh paint! It is not body shop safe. The only body shop safe QD is #34 Final Inspection!
    RamAirV1
    2006 GTO Impulse Blue
      ok, thanks! do I need to wash/rinse the dust off first?
        RamAirV1
        huh? Someone told me it was. I had a bird dropping on mine and used QD to clean it up. So what should I do? Go back and use scratch in the area where I sprayed QD to remove anything thats there?
        2005 Toyota Camry LE Phantom Grey Pearl
        2001 Toyota Corolla LE Silverstream Opalescent
        1996 Lexus ES300 Ruby Pearl
          I like those static car duster things. Looks like a stick with shag carpet on it.
            No, you just used it on a small area so don't worry about it. How long has it been since your car was repainted?
            RamAirV1
              RamAirV1
              A little over a month, used it to clean off bird droppings when it was 2-3 weeks old.
                I just picked up a bottle of #34 final inspection, what should I use to apply and remove it? bottle calls for a gold class supreme shine microfiber(X-2010)
                I don't have one of these, can I use a good quality 100% regular cotton towel? also, do I spray it directly on the dust,then wipe? I would use a seperate one for apply, and one for removal. safe to use same towels for repeated uses?
                on a side note, how do I wash off all the accumulated dust on my california car duster? (found it in a closet, very dirty) any recommendation on a good car wash concentrate,and how long do I wait before it's first washing?
                sorry for all the questions
                  You are not supposed to wash the duster. The more dust it picks up the better it works. Or so say the directions on the CCD. OXO makes a good duster too!
                  Only use the duster on a "dusty" surface. It is not for use on heavy dirt. Same with QDs. If you QD every day or other day, you will not need to wash as long as it doesn't rain and/or the paint otherwise get muddy!
                  RamAirV1
                    ok thanks
                    I hope the 100% cotton towel I mentioned previously will be ok to use for now. the car has a layer of dust on it, I can apply the #34 directly on the dust,then remove it with the towel? or do I run the duster over the car,then apply the #34, I just want to do it right the first time
                      Run the duster lightly over the paint first, then follow up with the #34.
                      The Supreme Shine MF towels work best. But if you have some top quality 100% cotton towels, like the no longer made Charismas, that would be OK. But they must be soft. I would recommend testing them on a small area first to make sure they don't cause swirls.
                      RamAirV1
                        ok, thanks. the towel I was considering was a clean 100% cotton Cannon bath towel that I cut up. I could always go buy a 3 pack of terry cloth polishing towels if I need to.
                          Just to clarify...
                          Quik Detailer is not formulated to be used in a body shop environment, that is where fresh paint is being sprayed.
                          Once the car leaves the body shop it is perfectly okay to use on paint that is less than 30 days old because Quik Detailer doesn't act like a wax in that it won't seal the paint.
                          You can use M34 Final Inspection if you like but it's also perfectly okay to use any of our other mist & wipe quick detailers once the car has left the shop.
                            thanks for that info
                            I've always wanted to try #34, as I have seen many satisfied users
                            have great results with it.
                              Sure smells yummy!
