Questions about some meguiars products
  • Questions about some meguiars products
    Hi Guys,
    I have a couple questions about the meguiars products that Im using.
    First question is that I have some Gold Class liquid wax that sat out in the garage over winter, and the ingredients in the wax appear to have separated and gotten chunky. Is the wax still ok to use?
    My next question is, what are the differences between the gold class liquid wax and the NXT liquid wax? What are the strengths of each and for which applications are they ideal for over the other?
    My last question, is the Cleaner Wax ok to use with a DA buffer?
    thanks!
    Evan
    Re: Questions about some meguiars products
    If the wax has frozen and won't re-mix then it probably won't perform the way it was intended.
    NXT Tech Wax is made using all synthetic ingredients
    Gold Class is a blend of synthetic and natural ingredients
    Both will make paint look great if the product is applied to the correct surface using good technique, NXT is Meguiar's best protecting wax.
    Yes you can use a cleaner/wax by machine.
      Thanks Mike, when I shake the bottle it re-mixes pretty well. So if its smooth and mixed, is it safe to use?
      As far as the cleaner wax, I mean the meguiars product called 'Cleaner Wax'. It doesnt specifically call out on the bottle that its ok to use a DA polisher, but id like to use it for quick all in one wax jobs if I can use it with a DA.
