Hologram- colorX then top it with NXT?
  • Hologram- colorX then top it with NXT?
    I have Holograms and swirl marks, will using ColorX then topping it off with Liquid NXT fill in those Holograms and swirl marks?
    thanks
    Re: Hologram- colorX then top it with NXT?
    It might help a little, but it probably won't get them completely out.
    To remove holograms, you need something a little more aggressive. I know that #83 DACP and a PC will remove holograms. For removing holograms, you need some sort of machine. ColorX will help a little, but it is not abrasive enough. If you are working by hand, some long hours with your friend ScratchX might help remove the majority.
    Chris
    Dasher Detailing Services
      thanks
      hi, try using m80 with pc followed by nxt tech wax or gold glass wax either one good choice. just like mike showed in how to use the pc video...
        Would 80 applied with pc be enought to remove holograms?
          How To Remove Swirls By Hand
          It all depends on how bad the holograms are, and what the paint itself is like. It might be enough, you might need #83, or you might need to go up to a rotary to get great results.
