when to use quick detailer????
  • when to use quick detailer????
    the problem is that a day after i wash and wax my car it gets all dusty. Is this what the qd was meant for? will it break down the wax(i use colorx) or do they like enhance it and make ist shine more/last longer?
    Re: when to use quick detailer????
    Here is a quote from the Meguiar's website:
    "Quik Detailer keeps a waxed car looking "just waxed". Clear coat safe, Meguiar's Quik Detailer removes harmful contaminants before they damage your finish. Use Quik Detailer right after your car is sprayed by a water sprinkler, hit by a bird dropping, or exposed to any other condition that ruins your "just waxed" appearance. The safe, high lubricity formula lifts off dirt and grim without scratching while enhancing gloss without build up. Details a full sized car in less than 15 minutes!"
    LINK
    You left out licking the water off. Oh, wait a minute, that's my cat, not my car. Uh, I mean my cat licks himself dry. I don't lick my cat dry. Or my car. -PC.
      QD is meant for exactly what the name says QUIK DETAIL.
      i use this in between wax jobs. so i usually wax on saturday or sunday and on say tuesday if i see its dusty i'll use QUIK DETAIL with two MF and get it back to its shine. its meant for in between jobs.
      it hasn't harmed my jobs that i've done.
      but there is a difference between DUST and DIRT. dirt can build up and using just QD and an MF can actually drag some chunks of dirt along your paint. this will require a wash if its dirt. if its only dust that's okay. yes it can lift dirt, but if its thick and you don't wash it, you can do more harm that good. just look at what it is on your car.
      i remember i waxed my car on a sunday, went for a drive and by early evening it was a little dusty as i hit up a country road and so ijust used QD and it was all GOOD.
      and YES it brings back that just waxed SHINE!!!
      its also good to use at SHOWS after you drive there if you don't tape the front end up.
