Need little more info!
  • Need little more info!
    Hi!
    I have just bought deep crystal system and also scratchx my questions is?
    After reading instructions on the bottles and some on the forum I feel like I need little more specific I tried to begin with step 1 cleaner byt did not get rid off some scratches then I tried ScratchX And on the bottle it says that after I rubbed it in I shall let it dry after removing but on your videos Barry ...says that only Wax has to dry after removing???
    How Is the best way to do with scratchX and the others 1,2,3 system Shall I rubbing in the Product until they dissapear and then dry?
    The step 3 Iknow how to do with wax only the others I am a bit ????
    I hope you understand my description "Coming from sweden"
    The car is a black toyota celica -00 with a lot of washing scratches....
    Re: Need little more info!
    Hi figgek,
    Removing swirls out of a clear coat by hand, not merely filling them is is difficult even for people that are experienced and good at this.
    It all comes down to technique and patience. First you can't tackle large areas at a time, in fact you have to only work small sections at at time, as in about a foot squared and then work your way around the car overlapping each little section you do.
    Most people when they realize how much work this is opt for finding a way to get a machine like our G100 to do the work for them. Being that you live in a country that uses different voltage than the U.S.you run into the same problems other people in countries with non-U.S. voltage run into and that's finding a machine or a power converter that will work for you.
    I'll snag some threads that discuss the techniques for working by hand and post them below.
      Most of the below will be from our Hot Topics forum and some from the How-to forum...
      In order to remove a scratch out of anything, metal, plastic glass, paint, etc. You must remove material around the scratch until the surface is level or equal to the lowest depths of the scratch or scratches.
      The below diagram if for paint, the the same thing applies to just about an surface material or coating.
      In essences, you don't really remove a scratch, you remove material around a scratch.
      Then the big question is, is the material or coating workable, as in can you abrade small particles of it and leave behind an original looking surface. For example, some things you can abrade, (remove the scratch), but you can never completely remove all of your abrading marks, thus you can't really fix the problem, all you can do is exchange one set of scratches of a different set of scratches.
      The next questions is, how thick is the surface material you're working on or the coating. You are limited to what you can do by the thickness of these to things, (surface coating or surface material), and whether or not this surface is workable.
      Sometimes you don't know what you can so until you try. It's always a good idea to test your choice of products, applicator materials and application process, (By hand or by machine), to an inconspicuous area. If you cannot make a small area look good with your product, applicator and process, you will not be able to make the entire surface look good. It's always a good idea to test first and error on the side of caution, versus make a mistake you cannot undo.
        Read these two all the way through... very good real-life examples...
        Not very happy with ScratchX
        ScratchX Works! - I Stand Corrected
          Which products need to dry before removing?
          When it comes to paint care, often times we'll have members post to our forum, which products and procedures they're using to detail their car. In the process they'll mention how long they let products like ScratchX, or Deep Crystal Polish, or #7 Show Car Glaze, or M80 Speed Glaze dry before they removed it.
          A common question that comes up often on our forum and over at our Customer Care Hotline is,
          • "How long should I let a paint cleaner dry?"
            or
            "How long should I let a polish dry?"
          This is a common mistake and/or misconception about these non-wax products, or in other words product meant to leave protection behind on the finish after removal. With this article, we hope to shed some light on this topic and clear up any confusion there may be on which products need to dry before removing them from the paint.
          When working inside the Meguiar's line of product, whether that's our Consumer Line, our Professional Line, or even our Mold Release Line, the only products that need to dry, and the only products you should allow to dry are our waxes.
          All other products are formulated and meant to be applied, worked-in and then removed immediately afterwards. This would include,
          • Compounds
          • Paint Cleaners
          • Cleaner/Polishes
          • Pure Polishes
          All Meguiar's waxes should be applied, worked-in and then allowed to dry until they pass the Swipe Test.
          This would include all Meguiar's paste waxes, liquid waxes and even our spray-on waxes.
          We hope this helps...
            Here's a classic on correctly using ScratchX
            The Viper in this picture was one we fixed at a class with about 60 eyeballs watching...
              How To Remove Swirls By Hand
              The below write-up was taken from page three of this Saturday Detailing Class at Meguiar's where approximately 25 people witnessed the products shown below, applied and removed using the correct techniques to remove the gross rotary buffer swirls and restore a swirl free finish by hand.
              San Diego Mercedes-Benz club at Meguiar's!
              After selecting two Mercedes-Benz automobiles to work on, one being Tom's, we broke for a pizza lunch. After everyone had their fill of pizza and something cold to drink, it was time to re-gather in Meguiar's Garage to see what we could do with the gross swirls in Tom's recently painted hood.
              Often times when the topic of removing swirls is being discussed on our discussion forum, or some other detailing forum, it centers around the dual action polisher, foam buffing pads and somebody's compound or polish. Yet many people don't own a dual action polisher. So here at Meguiar's Garage, we like to show people how to use the what they already own... their hands!
              Like most detailing enthusiasts, I personally love a challenge, and with Tom's car, I believe most people would agree, his car's finish presents a challenge!
              BEFORE - 700 Pixel-wide cropped out section from an un-touched, original photo of rotary buffer swirls in a clear coat finish.
              Using some painters tape, we taped-off a section of the hood to separate the before and after results. Then, we applied three, well worked in applications of Meguiar's ScratchX all applied by hand using Meguiar's High-Tech Applicator Pad
              The secret to removing swirls by hand using Meguiar's ScratchX is all in your technique. You see in order to remove swirls out of your car's finish, you need to remove a little bit of paint. If we we're to look at a horizontal view of what gross rotary buffer swirls look like in the paint, it would look something like the diagram below. In order to remove these below surface defects, (swirls), you need to remove enough paint from the finish to level the upper surface with the *****t depths of the swirls until you've restored the finish to a flat, level surface.
              To do this by hand with ScratchX, you need to,
              • * Apply to a small section at a time
                * First spread the ScratchX evenly over the area you're going to work (before working it in)
                * Work the microscopic diminishing abrasives against the finish applying a little passion behind the applicator pad
                * Repeat this process with multiple applications after first removing the residue from each application after working it against the finish
              Remember that Meguiar's paint cleaners, like ScratchX do not need to dry before removing. Drying adds no benefit. The only Meguiar's paint products that need to dry before removing are Meguiar's waxes.
              Technique Tip
              The question is often asked,
              "Which direction should I move my hand when applying a Meguiar's paint cleaner?"
              A common mis-conception, often espoused on other discussion forums, or by some car care product manufactures, is the technique of only rubbing a product in a certain direction to keep all of your scratches going in the same direction.
              Meguiar's teaches that if the products you're using are non-abrasive, that is they are not instilling scratches into the finish, as such, it shouldn't matter which direction you move your hand!
              If the products you're using are inflicting scratches into your car's finish, the correct thing to do is to stop using the product! Don't try to camouflage the scratches to your eyes by instilling them in straight-lines as determined by the movement of your hand.
              ScratchX can be applied using straight-lines or circular motion and for this particular demonstration we used a combination of both.
              Removing ScratchX using Meguiar's Supreme Shine Microfiber after working the product against the finish until the product has broken down, turned somewhat clear and begun to dissipate.
              At Meguiar's Saturday Detailing 101 classes, we go through a power point presentation that covers a wide spectrum of detailing topics, one of which is Meguiar's 5-Step Paint Care Cycle , which includes;
              • Step 1 Wash
                Step 2 Clean
                Step 3 Polish
                Step 4 Protect
                Step 5 Maintain
              After cleaning the paint with a paint cleaner like ScratchX, we then apply a pure polish, in this case, Deep Crystal Polish which is a non-abrasive pure polish.
              In Meguiar's line, we offer two types of polishes, cleaner/polishes, which contain a diminishing abrasive, and pure polishes, which are completely non-abrasive and are used solely for the purpose of creating brilliant gloss. Deep Crystal Polish is a pure polish.
              The way you apply a pure polish is akin to applying a skin lotion to your skin. That is you apply the polish to a small section at a time, work the product in thoroughly.
              After thoroughly, (but gently with care and passion), remove any excess polish with a clean, soft premium quality microfiber polishing cloth or 100% cotton towel.
              Like ScratchX a paint cleaner, it is not necessary to let a pure polish like Deep Crystal Polish dry before removing it. Allowing a polish to dry will not add anything beneficial to the process, so after you work it in well, go a head and remove it.
              At this point, we have cleaned and polished the finish. The cleaning step removed the swirls and the polishing step restored optical clarity, depth, reflectivity, richness of color and brilliant gloss. Next we're going to apply a coating of Meguiar's new NXT Generation Tech Wax Paste
              NXT Generation Tech Wax Paste is identical to NXT Generation Tech Wax Liquid except that it comes in a paste form. There are two types of paste waxes, the difference is in their consistency. The practical application difference is in how you remove them from the can and then apply them.
              With a cleaner/wax (paste), like Meguiar's A12 Meguiar's Cleaner/Wax you can scoop out a small amount and with your applicator pad and then apply it to the finish and work it in.
              With paste waxes like Gold Class Clear Coat Wax Paste, M26 Hi Tech Yellow Wax, and NXT Generation Tech Wax Paste, instead of scooping wax out of the can, you can twist, or spin your wax applicator against the wax while it's in the can and this little bit of agitation will help to liquefy the wax and enable it to seep, or penetrate into your applicator pad whereupon making it easier to apply to the finish.
              Paste waxes like NXT Tech Generation Wax offer good gliding action and tend to apply very easy. Remember a little bit goes a long ways and it's important to try to apply a uniform, thin coating.
              After applying the Tech Wax Paste and allowing it to dry, we removed it using a Supreme Shine Microfiber polishing cloth and the Tom backed his Mercedes-Benz out into the sun where everyone could look at the results and see with their own two eyes what can be accomplished by hand with the right products and the correct techniques.
              Here's the owner Tom inspecting closely!
              And here I am capturing the results with our Sony Digital which does an excellent job of capture swirls in the sun.
              Before
              After
              Perfect? No.
              dramatically improved? Yes!
              Most importantly, we fixed by hand what someone else inflicted with a rotary buffer.
              Meguiar's products, applied and removed using the correct techniques will outperform the competition hands down and give your car a swirl-free show car shine!
                Here's a good read also...
                Can I realistically get near-professional results with Meguiar's Consumer Products
                  Thx Mike I now understand little more I have done wrong first time I will try it again ....(to little pressure and time to rubbing in the product)
                    We're here to see you through to success in your garage!
